Home > Maintenance & Mods (L322) > IID Updater
Gary Williams
United Kingdom 2004 Range Rover Vogue Td6 Buckingham Blue
IID Updater
How do you get the IID Updater facility to work and recognise the BT G3!
Cheers
Gary
Post #721915 26th Jul 2025 5:50pm
steve2347
United Kingdom 2012 Range Rover Vogue 4.4 V8 Santorini Black
Hi Gary
There are some steps listed on page 45 of the manual, which you can grab here if you don't already have a copy.
https://www.gap-diagnostic.com/wordpress/w...lV4.00.pdf
Which steps have you been able to complete so far?
Post #721927 26th Jul 2025 9:14pm
Gary Williams
Hi Steve,
I have installed the updater software, run it and got the cannot find device error message. Does the IID need to be connected to the vehicle and is there something special with the supplied USB cable?
Cheers
Gary
Post #721933 27th Jul 2025 11:09am
Gary Williams
Just checked the Gap Support FAQ pages. Looks like they have not heard of Windows 10!
Post #721934 27th Jul 2025 11:19am
steve2347
I use windows 10 myself for the update, so I believe it should work fine.
I've taken some screenshots of the steps I used successfully.
Firstly, you only need to connect the gapiid to the PC via usb (no need for it to be connected to the car) and use the find device option.
It should find the device and connect automatically.
If the device is connected then you should be able to use the Program Firmware option, which will automatically detect your current firmware version and then compare this with the latest available.
Proceed with the update.
Once complete you should see something like the above.
Hopefully that helps, let me know!
Post #721935 27th Jul 2025 11:59am
steve2347
When you connect the device via usb does the led flash?
Post #721945 27th Jul 2025 2:41pm
Gary Williams
No, the led does not flash
When connected, I get a nothing detected on port 3 and no vehicle data displayed
Post #721946 27th Jul 2025 2:57pm
steve2347
Very possible it's an issue with that usb cable then. I don't have mine to hand at the moment but it looks like it's micro usb jack on the tool itself, which was a pretty common connection type until recently. You may have some lying around from older tech.
The original cable is quite short, and it's likely this is for signal integrity. When updating firmware this can be important, depending how the device handles the upgrade process. (If it writes the data to the device in a temporary location, confirms the integrity of the firmware and then flashes it vs writing directly from the PC to the memory itself). Not sure how much of an impact it would make for the Gap tool, but if you have a thicker, shielded cable that's short in length, it would be preferable to a long thin cable.
Post #721947 27th Jul 2025 3:12pm
pcourtney
I had issues to begin with, but now I have a short 1 metre USB cable that works every time, and also using Windows 10 on a laptop
NB Patrick sent me an update firmware earlier this year, and with this new USB cable it worked first time
Post #721949 27th Jul 2025 3:30pm
D3Jon
Some micro USB leads only have the internal wire connections to charge a device. These are supplied with things like Ebay / Amazon torches, etc. - things that only require power from their lead!
Other cables have the required data and charging lead connections, so try changing the USB lead you're using and see if your PC recognises the GAP tool then Thumbs Up
Jon 1992 RR Classic 3.9 efi Vogue
2014 Disco 4 HSE
Both my fatties now gone...
Previous: 2011 L322 4.4 TDV8 Vogue SE /// 2002 L322 4.4 V8 HSE /// 2009 Discovery 3 2.7 TDV6 XS /// 2004 Defender 90 TD5 /// 1993 110 V8 Snatch Landrover /// 2005 Discovery 3 2.7 TDV6 SE (Aus) /// 1990 110 Isuzu 3.9 County (Aus) /// 1976 Series III Trayback (Aus)
Post #721959 27th Jul 2025 7:22pm
knares
Australia 2005 Range Rover Vogue 4.4 V8 Zambezi Silver
looking at the pictures, "jaguar/landrover"
dose it cover jaguar as well RR 2005 4.4 petrol
Any spelling mistakes are the fault of spellchecker
Previous MG J2, CITROEN light 15 x 2 gone unfortunately
Present MERC 180e, RANGE ROVER L322, JAGUAR XJS, MERC 280SE, MG F, JAGUAR S-Type 6v 2003, jaguar s-type 8v 2004, Ford Cougar
Post #721965 28th Jul 2025 4:17am
steve2347
Looks like there is some beta support for Jaguar on the G4 under the vehicle coverage section
https://www.gap-diagnostic.com/products/iidtool/
Post #721966 28th Jul 2025 6:35am
Gary Williams
IID Updating sorted!
Hi All,
It was the cable/socket. I found two cables that clicked home more firmly and the IID was found on port 5. Possibly some usb cables were power only.
The update routine said to update the IID Control app to the latest version. I couldn't find this information in the app store but the app downloaded new files to my mobile anyway.
According to my mobile, I have version 4.2.3 Build 176. Does anyone know if this is the latest version of IID Control?
Thanks for everyones help Smile
Gary
Post #721970 28th Jul 2025 9:56am
knares
hahaha i have three jaguars, none of them are covered
mine must be a G3, as it works on my 2005 rover, if i update, it looks like it wont work and its not that long since i bought it, it is a BT RR 2005 4.4 petrol
Post #721974 28th Jul 2025 10:38am
steve2347
Re: IID Updating sorted!
Gary Williams wrote:
Hi All,
Gary
That's great news. When I checked my tool earlier I noticed it came with a ugreen branded cable, which is the "That'll be good enough" brand I buy from Amazon 😂
Mine is showing as version 4.2.11 Build 168, but I honestly wouldn't be too concerned about that.
Post #721976 28th Jul 2025 11:35am
