![]() | Home > Maintenance & Mods (L322) > IID Updater |
Gary Williams Member Since: 17 Jan 2017 Location: Essex Posts: 60 ![]() ![]() ![]() |
How do you get the IID Updater facility to work and recognise the BT G3!
steve2347 Member Since: 09 Jan 2025 Location: Reading Posts: 28 ![]() ![]() ![]() |
Hi Gary
Just checked the Gap Support FAQ pages. Looks like they have not heard of Windows 10! |
I use windows 10 myself for the update, so I believe it should work fine.
When you connect the device via usb does the led flash? |
No, the led does not flash
Very possible it's an issue with that usb cable then. I don't have mine to hand at the moment but it looks like it's micro usb jack on the tool itself, which was a pretty common connection type until recently. You may have some lying around from older tech.
pcourtney Member Since: 14 Jan 2020 Location: Stansted Posts: 942 ![]() ![]() ![]() |
I had issues to begin with, but now I have a short 1 metre USB cable that works every time, and also using Windows 10 on a laptop
D3Jon Member Since: 15 Aug 2020 Location: Lincolnshire Posts: 539 ![]() ![]() |
Some micro USB leads only have the internal wire connections to charge a device. These are supplied with things like Ebay / Amazon torches, etc. - things that only require power from their lead!
knares Member Since: 22 Jun 2017 Location: Perth WA Posts: 803 ![]() ![]() ![]() |
looking at the pictures, "jaguar/landrover"
Looks like there is some beta support for Jaguar on the G4 under the vehicle coverage section
Hi All,
