|  | Home > Maintenance & Mods (L322) > IID Updater |
| Gary Williams Member Since: 17 Jan 2017 Location: Essex Posts: 67      |
 How do you get the IID Updater facility to work and recognise the BT G3!
|  26th Jul 2025 4:50pm |
| steve2347 Member Since: 09 Jan 2025 Location: Reading Posts: 42      | Hi Gary
|  26th Jul 2025 8:14pm |
| Gary Williams Member Since: 17 Jan 2017 Location: Essex Posts: 67      | Just checked the Gap Support FAQ pages. Looks like they have not heard of Windows 10! | ||
|  27th Jul 2025 10:19am |
| steve2347 Member Since: 09 Jan 2025 Location: Reading Posts: 42      | I use windows 10 myself for the update, so I believe it should work fine.
|  27th Jul 2025 10:59am |
| steve2347 Member Since: 09 Jan 2025 Location: Reading Posts: 42      | When you connect the device via usb does the led flash? | ||
|  27th Jul 2025 1:41pm |
| Gary Williams Member Since: 17 Jan 2017 Location: Essex Posts: 67      | No, the led does not flash
|  27th Jul 2025 1:57pm |
| steve2347 Member Since: 09 Jan 2025 Location: Reading Posts: 42      | Very possible it's an issue with that usb cable then. I don't have mine to hand at the moment but it looks like it's micro usb jack on the tool itself, which was a pretty common connection type until recently. You may have some lying around from older tech.
|  27th Jul 2025 2:12pm |
| pcourtney Member Since: 14 Jan 2020 Location: Stansted Posts: 1032      | I had issues to begin with, but now I have a short 1 metre USB cable that works every time, and also using Windows 10 on a laptop
|  27th Jul 2025 2:30pm |
| D3Jon Member Since: 15 Aug 2020 Location: Lincolnshire Posts: 575    | Some micro USB leads only have the internal wire connections to charge a device.  These are supplied with things like Ebay / Amazon torches, etc. - things that only require power from their lead!
|  27th Jul 2025 6:22pm |
| knares Member Since: 22 Jun 2017 Location: Perth WA Posts: 836      | looking at the pictures, "jaguar/landrover"
|  28th Jul 2025 3:17am |
| steve2347 Member Since: 09 Jan 2025 Location: Reading Posts: 42      | Looks like there is some beta support for Jaguar on the G4 under the vehicle coverage section
|  28th Jul 2025 5:35am |
 Hi All,
|  28th Jul 2025 8:56am |
 hahaha i have three jaguars, none of them are covered mine must be a G3, as it works on my 2005 rover, if i update, it looks like it wont work and its not that long since i bought it, it is a BT RR 2005 4.4 petrol Any spelling mistakes are the fault of spellchecker Previous MG J2, CITROEN light 15 x 2 gone unfortunately Present MERC 180e, RANGE ROVER L322, JAGUAR XJS, MERC 280SE, MG F, JAGUAR S-Type 6v 2003, jaguar s-type 8v 2004, Ford Cougar | ||
|  28th Jul 2025 9:38am |
 That's great news. When I checked my tool earlier I noticed it came with a ugreen branded cable, which is the "That'll be good enough" brand I buy from Amazon 😂 Mine is showing as version 4.2.11 Build 168, but I honestly wouldn't be too concerned about that. | ||
|  28th Jul 2025 10:35am |
| Posting Rules
