Home > In Car Electronics (L322) > Original Headunit CarPlay for $200
Page 2 of 3 <123>
exyjerome
United Kingdom 2012 Range Rover Vogue SE 4.4 V8 Santorini Black
I've been using it for a few weeks now and it's definitely a noticeable upgrade. Since the original head unit powers on as soon as you unlock the car, CarPlay starts pairing right away. By the time I've opened the boot or sat down, it's usually already connected.
The audio quality is solid and sounds better than the Android unit I had before. On hot days, the old head unit would often fail to power on and needed cooling down, but I haven't had any such issues with this one.
All of my original functions still work, like the 360 camera, rear entertainment, and TV. It's also a lot easier to access.
I'd definitely recommend it!
Post #721658 21st Jul 2025 11:18am
madnessgonemad
Thank you for that.
I’ve ordered one. I had to pay £200 which I think is very good for the original look.
Would it be ok to ask you for help if I have any wiring issues?
I’m ok with dismantling the dash. I’ve done that a few times now
Post #721734 22nd Jul 2025 8:06pm
exyjerome
Of course, happy to help however I can.
I followed Sam's video here:
He moves pretty fast once the head unit is open, but the ribbon cables only fit into their correct slots, so it's fairly straightforward.
Post #721736 22nd Jul 2025 8:19pm
madnessgonemad
Many thanks.
Should be ok but nice to know!
Post #721739 22nd Jul 2025 9:38pm
landy95
My unit arrived last Thursday. I fitted it yesterday, all working.
Stripping the dashboard down wasn't too bad, I added the daughter board which was fairly simple as it was just ribbon cables, temporarily fitted the head unit and had no picture on power up. I stripped it 4 times before I got a picture, one of the ribbon cables wasn't pushed in far enough.
Putting the dash back and glove box etc was a ball ache, but managed it, although some aching muscles from the contortion required.
I haven't had much time to play with it as i moved on to turbo oil feed o ring replacement and throttle body sealing improvement as recommended on Sams motor and machine
Many thanks for highlighting this unit exyjerome, I had been contemplating spending £600 on the uad unit. Saved a pretty penny. And I also was not charge import duty or vat.
I will comment on how it performs once I have used it properly.
Cheers.
 Also own a 1976 Land Rover 101 3.5 V8.
Previously owned:-
2012 Range Rover Westminster.
1991 Range Rover Vogue 3.9 V8.
Post #721960 27th Jul 2025 9:06pm
exyjerome
Glad to hear I wasn't the only one who didn’t get the ribbon cables seated properly the first time — took me four goes as well!
Agree on the glove boxes, definitely the most frustrating part. Would have been much easier with an extra pair of hands.
Looking forward to hearing how you get on with it. I’ve done a fair few miles with mine over the weekend and it’s been behaving itself so far, fingers crossed it stays that way!
Post #721962 27th Jul 2025 10:01pm
knares
Australia 2005 Range Rover Vogue 4.4 V8 Zambezi Silver
well done guys, i wouldn't like to tackle that RR 2005 4.4 petrol
Any spelling mistakes are the fault of spellchecker
Previous MG J2, CITROEN light 15 x 2 gone unfortunately
Present MERC 180e, RANGE ROVER L322, JAGUAR XJS, MERC 280SE, MG F, JAGUAR S-Type 6v 2003, jaguar s-type 8v 2004, Ford Cougar
Post #721964 28th Jul 2025 4:09am
RobsterPC
How have you found the screen quality and the responsiveness of the system? I like my top mounted screen but I'd like to replace it properly with a more integrated solution.
Regarding the controls and audio, is this true wireless? By that I mean you don't need a 2nd bluetooth adapter or something plugged into the iPod port and AUX input in the car? And do all of the controls work, fast forward, rewind etc?
Post #723984 5th Sep 2025 8:45am
exyjerome
The screen quality isn’t as good as a modern Android display or the built-in screens in newer cars, but it’s still decent and everything is clear and easy to read. It feels pretty responsive and I haven’t had any issues with lag or readability.
It’s a completely wireless setup since my phone only connects to the unit’s Bluetooth. You do need to switch the car audio to AUX for sound, but nothing is actually plugged into the AUX port. All the controls work properly too, like forward, rewind, and volume. On my previous unit there was a long delay when skipping tracks, sometimes 20 seconds, but this one responds within a second or two.
Post #723985 5th Sep 2025 9:05am
Baltic Blue
Just for comparison, I’m 5 months into my upgrade.
I paid to get it installed, but if anyone is thinking of a DIY upgrade, then assuming you can get the unit for c£300 compared to c£175 to upgrade existing head unit, I would suggest getting the new unit because , touch wood, it has performed faultlessly and I am still amazed at the screen and sound quality, definitely worth the extra outlay and no ribbon cable internal work.
Cheers
Mike.
 G reg 2.5VM Vogue Portofino red 1991- 1999
Post #723986 5th Sep 2025 9:19am
IMissNimoy
United States 2011 Range Rover HSE 5.0 V8 Zermatt Silver
Sorry to be daft but which unit is this? Looks great! Does it improve the in-cabin phone microphone quality?
Update: I found the thread where you "bit the bullet". Smile 2011 L322 HSE Lux 5.0 NA
Post #724847 20th Sep 2025 4:03pm
shalz
Kenya 2011 Range Rover Vogue TDV8 Santorini Black
Gents,
Just stumbled onto this thread whilst looking for cheap Bluetooth fixes.
What is the recommended unit to go for, noting i will be self-installing?
Looking for one that doesn't have issues in heat etc as will be installing in Kenya so hot weather most of the time.
I would have preferred Lee to install but obviously wont work.
Thanks. MY11 Vogue 4.4 TDV8 - "African Queen"
Post #726296 17th Oct 2025 7:07am
exyjerome
It really depends on what you want. If you prefer to keep the original features or like the factory look, go for the one mentioned in this thread. The Android unit has a nice large display, but mine tended to struggle a bit in the heat and was really only good for CarPlay. Both options involve removing the dash and take about the same amount of time to install. The original CarPlay unit is a bit more involved since you need to take the old head unit apart, fit a new board, and connect two ribbon cables. It’s not difficult, just a bit time-consuming.
Post #726306 17th Oct 2025 8:56am
shalz
To be honest I am not fussed on the look.
Need something reliable and good for android auto as we mostly have that in the house.
Needs to work with the sound and reverse camera.
Installation will be the challenge as its something ive never done before but I did change a simple head unit on a cayenne (didnt require dash removal though).
Any updated link to the exact one to get as ive seen one on this thread and also on another and still a bit confused? MY11 Vogue 4.4 TDV8 - "African Queen"
Post #726308 17th Oct 2025 9:00am
exyjerome
If you want the OEM one: https://www.alibaba.com/product-detail/Den...76e9TR4Atp
For the Android unit it’s this: https://www.aliexpress.com/item/1005007948754695.html
I know a few others here have the Android unit and had no issues. I had it for a month or so but got tired of the overheating and installed the OEM one instead, and haven’t had any problems since.
https://www.fullfatrr.com/forum/topic67642.html - I used this for taking the dash apart and it wasn’t too bad. Whichever option you choose, feel free to post here if you get stuck and we can help.
Post #726310 17th Oct 2025 9:19am
Page 2 of 3 <123>
