![]() | Home > Maintenance & Mods (L405) > Sunroof Drains - Just in time? |
Kot Member Since: 10 Mar 2021 Location: Broadland Posts: 1440 ![]() ![]() |
+1 Thanks for the reminder, I really need to check these |
adara Member Since: 09 Dec 2008 Location: Eastern Europe Posts: 884 ![]() ![]() ![]() |
I just checked mine—right now, the left one looks worse.
Alistair Member Since: 11 Feb 2011 Location: Peterborough / Alicante / Andorra Posts: 8134 ![]() ![]() ![]() |
Looks like I need one (or maybe 2) so just looked them up
Are you sure about the diameter? It looks more like 7.5 - 8mm, not 10... The 10mm diameter seems to be OK for complete replacement, not for inserting in the already existing pipe. |
I just took it from the video I linked to - it's in the description on YouTube - I haven't actually measured |
ReggieMac Member Since: 10 Sep 2023 Location: Wolverhampton Posts: 280 ![]() ![]() ![]() |
This is what I used, event though these are sold out there are plenty other types that do the same job. Dimensions are in the attached image. They were an absolutely lovely fit and pushed in quite easily with a little effort. They do sit slightly proud of the original but as you can see from the first images they drain perfectly well.
Thank you so much for the details. I was able to find a seller on eBay based in the UK but who ships to Europe. It seems this product is either unavailable elsewhere, goes by a different name, or I'm just having trouble locating it. |
RRYorks Member Since: 13 Jan 2020 Location: Yorkshire Posts: 53 ![]() ![]() ![]() |
I agree with you, no way will 10mm go in, 7.5mm drill was the largest I could use. Mine is 2018 model, perhaps they use a thicker tube on later models? 2018 4.4 TDV8 |
If you look at the diagram a couple of posts up, you'll see that despite being referred to as 10mm, they are actually narrower.
Rob99 Member Since: 03 May 2016 Location: Gatwick Posts: 1482 ![]() ![]() |
Those inserts are to fit inside Hep2o pipe which has an internal diameter of 6.7mm 2021 D350 Fifty Edition - Carpathian Grey
Extol Member Since: 13 Jan 2024 Location: London Posts: 18 ![]() ![]() ![]() |
I did do this couple of months ago, bought the 10mm stainless inserts from Toolstation, and used some 3M epoxy glue to fit them in. it fits perfectly. It is very easy to clean now with small pipe cleaner.
tark Member Since: 24 Jun 2025 Location: Gdansk Posts: 2 ![]() ![]() |
Sorry for a possibly dumb question, but I thought the whole drain pipe can disintegrate. Is it not so? Does this insert help cause only "intake" is affected by rust?
The video I linked above should explain it.
Actually thought metal tubes go much deeper, now it makes sense.
