![]() | Home > Technical (L405) > front knuckle cracking |
| JamboM3 Member Since: 28 Jul 2021 Location: Berkshire Posts: 277
That’s positive!
| woodyrvf750 Member Since: 10 Jul 2023 Location: Stratford Upon Avon Posts: 43
JLR have requested the broken one. They probably just want to check the serial numbers, who knows.. |
| DrF Member Since: 30 Jun 2014 Location: South East Posts: 1526
I would be checking myself, as if it does fail, your dealer will absolve themself of any responsibility and you are then left with having to sort it out.
| Mike Edwards Member Since: 13 Feb 2021 Location: Northampton Posts: 283
My thoughts exactly. |
| Gremlin500 Member Since: 11 Mar 2022 Location: Newcastle, UK Posts: 1900
I’d just like to suggest new readers of this thread read the ENTIRE thread before posting.
| Dave lincs Member Since: 31 Dec 2021 Location: louth Posts: 43
Hi I have a 2015 65 plate which has got the dreaded cracks but outside the recall I have contacted JLR and am taking it to Duckworth at market rasen on Monday for them to investigate the car |
Dave Lincs
Done as requested, Has anyone been successful with getting this fixed if not in vin range |
| 4RRS Member Since: 13 Apr 2022 Location: Crudgington Posts: 458
Got both sides on my 2016 outside of vin range replaced without any argument, even got a new o/s driveshaft when they destroyed it removing the knuckle.
| MadManxJim73 Member Since: 01 Aug 2025 Location: Retford Posts: 1
Would love to know what pressure can be applied to JLR - I've a 09/15 registered MY2016 and Duckworth have just confirmed its not subject to a recall for this - VIN ends GA253xxx - which I thought was within range.
| Dolphinboy Member Since: 07 Dec 2009 Location: Bristol Posts: 3284
Here is the letter they sent. my VIN is GAZ 654 Note the program number N759 (required by the dealer on application for inspection)
My only recommendation would be to keep all the parts removed, log the incident with DVSA and keep hold of your invoice from OFG Lincoln with a view to claiming back the cost should the recall be extended! https://contact-dvsa.service.gov.uk/report-vehicle-safety-defect/ |
| mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 8002
This just came up randomly in my FB feed. Someone with a 405 compared failed one to replacement and said new one is cast thicker….
| All times are GMT |
