Home > Maintenance & Mods (L405) > Sunroof Drains - Just in time?
Kot
Screwfix sell them £4.99 for pack of 10, and they also sell No Nonsense 2-Part Epoxy Adhesive Tubes Opaque 30ml £4.49
All stocked up, just waiting for recent hand surgery to heal and stitches out Thumbs Up 2018 SE SDV8 4.4 Byron Blue
Post #722392 6th Aug 2025 9:55am
Monty+4
United Kingdom 2019 Range Rover Autobiography TDV6 Loire Blue
I have obtained some brass inserts to the same design and size as those mentioned.
As a precaution I checked compatibility of the different metals, it appears that brass in most applications is fine with steel, it is not with carbon or stainless steel in a wet environment, I also noted that mild steel and stainless steel are not compatible in a wet environment, the differential is likely to increase the speed of corrosion in the mild steel component.
I guess the epoxy will possibly insulate the two components from each other
Does anyone know what metal is used in the sunroof drains?
Post #722408 6th Aug 2025 2:58pm
Monty+4
Post #722409 6th Aug 2025 2:58pm
adara
Romania 2019 Range Rover Vogue 2.0 PHEV Santorini Black
I'm not entirely sure about using brass and steel together—refer to the table below for more details. Brass sleeves are readily available in various sizes, but from what I've read, they're not recommended. That’s why I opted for the Wavin inserts instead.
Post #722411 6th Aug 2025 3:51pm
