Home > Technical (L405) > Identifying small sensor in rear window
tomiRR
2013 Range Rover Vogue TDV6 Aleutian Silver
Dear Friends,
Can you please help me to identify the small sensor-like part behind the rear window’s lower section?
I don’t know if I have to replace mine or only the cover is missing.
Thank you in advance!
Tom
Post #723315 23rd Aug 2025 5:23pm
Gremlin500
Yes, it's the daylight sensor, possibly just the cover has fallen off, if it stops working your auto lights won't switch between day DRL and night mode, not sure what other functions it supports. V6 Vogue - “Less is More” - less to go wrong!
Post #723320 23rd Aug 2025 6:46pm
tomiRR
Thank you very much!
It works fine luckily.
I have to cover it slightly to keep this state Smile
Post #723321 23rd Aug 2025 6:48pm
jimmie
Poland 2004 Range Rover Vogue 4.4 V8 Epsom Green
nope. this is sunload sensor for a/c control. The same as the front one. drl has nothing to it. Light sensor is under rearview mirror.
Post #723323 23rd Aug 2025 7:17pm
tomiRR
Actually I found out that it has dual function:
Sensing sunload and temperature. It regulates AC fan speed depending theese two factors.
Thank all to you guys.
Just ordered a used one from ebay for 15,- pounds. Cover needed only and will have a spare one.
Tom
Post #723324 23rd Aug 2025 7:38pm
jimmie
just measures sun energy from two sides. no temperature
Post #723340 24th Aug 2025 7:04am
