![]() | Home > Technical (L322) > ZF5HP 24 Gearbox - Delayed and harsh engagement |
Dolphinboy Member Since: 08 Dec 2009 Location: Bristol Posts: 3252 ![]() ![]() ![]() |
RRPhil is the God of these gearboxes on here. I am sure he will be along to offer some sage advice. |
RRPhil Member Since: 22 Aug 2011 Location: Blackburn, Lancashire Posts: 1026 ![]() ![]() |
Does this result in the TRANS. FAILSAFE PROG warning being displayed in the message centre? Phil |
steve k Member Since: 05 Apr 2024 Location: Berkshire Posts: 58 ![]() ![]() ![]() |
Hello Phil, many thanks for you question. No warning messages relating to the gearbox upon taking delivery or since doing the work so far. The car was delivered on a recovery and I have only been able to drive it around a small paddock before putting it up on stands so possibly its not been driven enough?
So, just to confirm, if you measure the resistance between pins 2 and 16 at the 16-pin connector you get an open circuit?
Hi Phil
Accessing the 16-pin plug is a pain. I made up this little breakout board to make it easier to read of the resistances.
Wow - blimey! many thanks. I will compare the correct wiring to my results and see where it leads. This is very helpful Phil - Current: 2003 TD6 HSE
With the proper wiring diagrams I have re-checked the connections from the ECU box down into the box and back my results confirm the internal gearbox wiring is faultless.
