![]() | Home > Technical (L322) > ZF5HP 24 Gearbox - Delayed and harsh engagement |
Dolphinboy Member Since: 08 Dec 2009 Location: Bristol Posts: 3273 ![]() ![]() ![]() |
RRPhil is the God of these gearboxes on here. I am sure he will be along to offer some sage advice. |
RRPhil Member Since: 22 Aug 2011 Location: Blackburn, Lancashire Posts: 1036 ![]() ![]() |
Does this result in the TRANS. FAILSAFE PROG warning being displayed in the message centre? Phil |
steve k Member Since: 05 Apr 2024 Location: Berkshire Posts: 63 ![]() ![]() ![]() |
Hello Phil, many thanks for you question. No warning messages relating to the gearbox upon taking delivery or since doing the work so far. The car was delivered on a recovery and I have only been able to drive it around a small paddock before putting it up on stands so possibly its not been driven enough?
So, just to confirm, if you measure the resistance between pins 2 and 16 at the 16-pin connector you get an open circuit?
Hi Phil
Accessing the 16-pin plug is a pain. I made up this little breakout board to make it easier to read of the resistances.
Wow - blimey! many thanks. I will compare the correct wiring to my results and see where it leads. This is very helpful Phil - Current: 2003 TD6 HSE
With the proper wiring diagrams I have re-checked the connections from the ECU box down into the box and back my results confirm the internal gearbox wiring is faultless.
Hi Phil
Can you just confirm that you definitely have a '350' valve body assembly (in case someone in the past has swapped it out for an earlier assembly without all the later mods)
Hi Phil
As you mentioned, SV-1 & SV-2 both use the same spring (0732 041 462) – which is also used for KV-D & KV-E – and SV-3 uses a 4mm shorter spring (0732 041 826), but with the same outside diameter and wire gauge.
Thanks again Phil. |
