Home > My Range Rover > L322 5.0 autobiography Sumatra Black - ownership journey
Page 4 of 8 <12345678>
theJAFman
United Kingdom 2010 Range Rover Autobiography 5.0 SC V8 Baltic Blue
Update
Barb fitting hose worked no coolant leaks or from anything i touched
Front bumper complete foglights and pdc working all round!
Having issues bleeding this thing
There are 3 bleed points?
Heating on to max heat lowest fan front and rear
Expansion tank prefilled to max start engine
Open front metal pipe with the bung till coolant flows put pipe gets hot close it
Open expansion bleeded till flow close
Open rear left corner hardpipe bleed for hvac system till it flows and close
But i had pressure build up and temp went just past 12 0 clock wtf any full fat nerd help?
Post #723674 30th Aug 2025 9:36pm
pcourtney
what a special service you have given the old girl there, much respect from me also Smile
Post #723676 30th Aug 2025 9:51pm
theJAFman
Thanks mate its getting there !
Just need to figure out how to bleed her front heating is now piping hot but no luck for the rear yet
After this its 1 front shock and worlds of cleaning for the most part
Post #723677 30th Aug 2025 10:04pm
dhallworth
The instructions in the manual say that you need to hold the revs at 2k rpm or something like that whilst bleeding. It's been a while since I did mine. I followed the manual but didn't have any issues bleeding it.
The other option you have is to use a vacuum bleeder. I bought one to do mine but ended up not using it.
Post #723678 30th Aug 2025 10:12pm
theJAFman
Thanks david, where can i find this manual, surely you dont mean the book itself?
Post #723679 30th Aug 2025 10:13pm
Rackers
United Kingdom 2010 Range Rover Autobiography TDV8 Santorini Black
I had to use a vacuum purge & refill kit to successfully bleed my 5.0. Tried and tried with the bleed ports but these things are a notorious PITA to bleed manually.
Post #723680 30th Aug 2025 10:14pm
dhallworth
Apologies, the workshop manual. I'll try and find it just now. 2002 4.6 Vogue SE - Alveston Red with Lightstone Leather
Post #723682 30th Aug 2025 10:18pm
theJAFman
Thank you that would be amazing
Post #723684 30th Aug 2025 10:26pm
dhallworth
I've managed to get the cooling system bleeding instructions from the entire workshop manual into a 4 page document. Here's the instructions:
https://www.dropbox.com/scl/fi/8mc1rsyxqlh...a&dl=0
Post #723687 30th Aug 2025 11:48pm
theJAFman
Thank u soo much that looks like different car but i just found a working link to procedures!
https://charm.li/Land%20Rover/2011/Range%2...%20Repair/
I will have to wait till morning to retry as it needs to be done from dead cold i believe 2 to 3 hours wont be enough
Post #723688 31st Aug 2025 12:17am
theJAFman
Edit that is the expansion tank
I think i get it not
Open 4 bleed points
Brim expansion tank with coolant and it will magicly start circulating with engine off? Surely ignition for the electric charger one?
Once coolant bleeds through each bleed port close them off 1 by one
Check level fill to max mark and start engine with heaters all round on max temp and fan?
Fast idle 1500 2 mins till front is hot
Check rear if rear is not hot then 3000rpm 30 seconds at a time till rear is hot then fill check
Close expansion tank
Run at 2k for 8 mins and turn it off
If it passes this cycle the system is bled....
I find out tomorrow
Post #723690 31st Aug 2025 2:57am
theJAFman
Here goes nothing
Post #723702 31st Aug 2025 12:44pm
theJAFman
Same result with rear remaining cold and car starts to overheat
Sick of mess car now outside with hose handy
Hopefully the angle will help it bleed bubbles to top
Post #723703 31st Aug 2025 1:28pm
theJAFman
Car is now fully bled all 4 zones primed with hot air. I needed quite the incline to get the air out
Car ran for 20 mins at 2k rpm with no max engine fan or overheating.
20kg of crazy audio removed who ever did this was a artist with all custom fabricated brackets and PO musta spent a few K
Oem audio is pretty Censored but its a family car who cares rather sell this stuff a few hundred squids. Maybe in the future some proper oem plus stealth upgrades if its gooden, it better be after all this pampering
Now insure it bed the brakes and do handbrake adjusting process
Come back give it a good detailed clean
Cermaic coat bonnet wings and 2 new bumpers for now
Get it in the air again take both front wheels off button up arch liners under trays and soak up front right shock bolts. Change oil.
And if all is well on Tuesday go on a crazy road trip
Post #723707 31st Aug 2025 4:55pm
theJAFman
Guys any idea where this green plug goes? Im guessing its somthing do with factory audio
Post #723708 31st Aug 2025 5:09pm
