|  | Home > My Range Rover > L322 5.0 autobiography Sumatra Black - ownership journey |
| theJAFman Member Since: 02 Aug 2025 Location: London Posts: 109      | Thanks option 2 it is! | ||
|  17th Sep 2025 12:30pm |
| theJAFman Member Since: 02 Aug 2025 Location: London Posts: 109      | The dreaded ac pipe repair
|  18th Sep 2025 1:21pm |
| Gsxr1250dave Member Since: 20 Oct 2018 Location: London Posts: 1057    | That will do the job nicely 👌 it's how I fix all of mine. It took 2 attemps to fill with gas only because the valve in the ac pump was stuck due to it being out of service for so long. Vacced out the 1st attempt via the machine yhen on yhe end attempt refilled in minutes.
|  18th Sep 2025 5:10pm |
| theJAFman Member Since: 02 Aug 2025 Location: London Posts: 109      | Thanks Dave you are now my Ac repair hero! | ||
|  18th Sep 2025 8:15pm |
| theJAFman Member Since: 02 Aug 2025 Location: London Posts: 109      | The love continues
|  19th Sep 2025 10:58pm |
| rvbush Member Since: 08 Jan 2016 Location: Leamington Spa Posts: 569      | They're the bulbs I've used, brilliant!! Drives:
|  20th Sep 2025 10:08am |
| theJAFman Member Since: 02 Aug 2025 Location: London Posts: 109      | Fantastic
|  20th Sep 2025 10:21am |
| rvbush Member Since: 08 Jan 2016 Location: Leamington Spa Posts: 569      | Yes, very!! And, if anything, the beam pattern is sharper. Drives:
|  21st Sep 2025 7:29am |
| kevinp Member Since: 28 Sep 2019 Location: Telford Posts: 1364      | Yes, best upgrade I've done to my car. Incredible difference.  | ||
|  21st Sep 2025 8:53am |
| theJAFman Member Since: 02 Aug 2025 Location: London Posts: 109      | Thanks guys
|  21st Sep 2025 9:15am |
| theJAFman Member Since: 02 Aug 2025 Location: London Posts: 109      | Went to try get ac filled today
|  22nd Sep 2025 10:32am |
| Gsxr1250dave Member Since: 20 Oct 2018 Location: London Posts: 1057    | If you have a small air tank/compressor you can track down leaks using compressed air in the system. I made a small attachment up so i could fill the ac with good old air which helped me find my leak.
|  22nd Sep 2025 5:21pm |
| theJAFman Member Since: 02 Aug 2025 Location: London Posts: 109      | I have a fair sized air compressor i couldnt think of relevent fittings to adapt to test the line myself like this
|  22nd Sep 2025 5:25pm |
| Gsxr1250dave Member Since: 20 Oct 2018 Location: London Posts: 1057    | I always use fernox hawk white in my fittings it's rated for 5 bar for gas and 7 bar for water the actual fittings are rated at over 200 psi from memory and 10mm copper pipe over 1000 psi so either the fittings are not nipped up enuff or there is another leak.
|  22nd Sep 2025 5:52pm |
| All times are GMT | < Previous Topic | Next Topic > |
| Posting Rules
