![]() | Home > Maintenance & Mods (L322) > How Seized Engine Out L322 2011 4.4 TDV8 ? |
Steveg Member Since: 06 Apr 2024 Location: Norfolk Posts: 69 ![]() ![]() ![]() |
You can pull all the front off, and propshafts off etc. - then drop engine and gearbox in one go. I’ve seen people drop them onto a long pallet and then use a pallet truck to pull it out and then move around. |
When I changed my wife's engine at home, we removed the front end. Rad packs out. The full monty... Then we yanked it out of the front after removing ancillaries like the starter and anything that looked in the way... But it pretty much came out of the front as a whole unit, with heads & induction system still intact...
Here’s a couple of threads that might be useful for rebuild…
RangerRover Member Since: 19 Aug 2025 Location: Munich Posts: 10 ![]() ![]() ![]() |
Thanks guys. Really appreciate this community!
Very interesting update.
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8776 ![]() ![]() ![]() |
To me that sounds like it seized due to overheating, had this before in engines, totally locked after overheating then free up later... I would guess there will be pickup marks on the bores... worth a probe with an endoscope though.... Worth a try...
Thanks mate.
Get a smaller endoscope is all I can think of... |
After 6 hours of putting the bolts back on , putting the exhaust back on , I idiot checked the oil filter so late. It is full of chips and the crank sometimes turns smooth and then suddenly blocks. So the verdict must be , Engine bearing gone. I hope this is the only damage. So today 6 hours again screwing everything out and get ready to lift the engine out.
Another question. Is there a workshop manual for the 2010 L322 with TDV8 4.4 ? I only find one from 2002 which is great. And a collection of topix steps in a zip folder. |
Starter out after 2hours naming him a piece of S&%$.
