![]() | Home > Technical (L322) > 2007 L322 4.2 V8 SC Battery Drain / Parasitic Drain |
Dick_ Member Since: 31 Aug 2025 Location: London Posts: 6 ![]() ![]() ![]() |
Well the car just started first time after the Derby trip yesterday and being left overnight.
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8789 ![]() ![]() ![]() |
All fatties are very susceptible to low volts.
There is an explosive disconnect on the + side, there is a procedure for replacing the battery, you can find it in the workshop manual downloadable from the WIKI, link above right... Pete __________________________________________________ 2014 L405 Autobiography SDV8 4.4 Loire Blue Ebony interior -Click here for Thread- 2012 L322 Autobiography 5.0 Supercharged Ipanema Sand Sold 2011 L322 Vogue SE 4.4 TDV8 Baltic Blue. Sold 2002 L322 Vogue 4.4 V8 Epson Green (Fatty Offroader) Sold -Click here for Project Fatty off roader- |
dingg1 Member Since: 29 Jun 2013 Location: PORTUGAL Posts: 1404 ![]() ![]() |
Firstly change the battery, it's probably due a new one, type 019, go agm they last longer ime, you can squeeze a type 020 in but again imo better for an agm type 019.
Thanks all
Just one further question right now:
If it was me I'd use the one recommended, which is the one you have IIRC... |
Recommended battery fitted and car definitely started a lot quicker and with more conviction!
You can tell fatty it has a new battery with a diagnostic tool but it will learn on it's own, just takes a bit longer for it to sort itself out.
Having had a Disco 3 for a few years, I can confirm a Gap IID tool was the first thing I bought as I was on the way home from picking up the car!
