Home > Technical (L322) > 2007 L322 4.2 V8 SC Battery Drain / Parasitic Drain
Dick_
United Kingdom 2006 Range Rover Supercharged 4.2 SC V8 Java Black
Ok, so I know there’s a few posts on this, but they’re all a bit old, not that that’s an issue as the theory and the underlying cause has likely not changed, however I thought as a baptism of fire both to the forum and the L322 I’ve just bought I’d document my struggles, as I can’t see a forum post which comprehensively works through the old battery drain issues front to back.
When I first picked up the car, I drove back from Birmingham to London. Parked it up, left it overnight, next morning all started fine, no issues.
Drove it about half an hour to a place where it was getting a polish and ceramic coat, detailer calls me three days later and tells me the battery was flat and that it’s got a parasitic drain.
Sure enough after driving it home from the detailer and leaving it overnight, battery is flat and it won’t start.
Jumped it with a Noco jump pack and quickly got going - drove to Derby and back and the battery is fully charged on return but showing a “health” on my battery tester of only 57%.
Just tested the battery again after sitting overnight and got a 12.11V charge left in it and ‘health’ now showing as 37% with only a 486CCA capacity.
Whilst I’m on the way to Screwfix / Toolstation to pick up a multimeter and a clamp meter, can anyone tell me with any confidence if this sounds like
A) my battery is knackered
B) there is some kind of drain
C) both
The current battery is a Bosch unit which I have no idea how old it is, and is 800A / 95AH.
Is that the recommended battery rating for a 4.2SC?
Should my first port of call be to switch over the battery for a 900ah 100A Yuasa 5000 I have sat new, spare and fully charged, before bothering to explore parasitic drain as an issue?
Are 4.2SC L322s particularly battery hungry?
Thanks for any help in advance - thoroughly overjoyed to be part of the L322 club, been a long time overdue!
Post #724108 7th Sep 2025 3:08pm
Dick_
Well the car just started first time after the Derby trip yesterday and being left overnight.
I’m hoping this is just a case of a knackered battery.
But just in case I reckon I’ve got all the (gear and no idea) kit I could now need to track and issues down otherwise.
Had to stop myself buying Fluke everything and was fortunately limited by what was in stock at the local outlets at 15:30 on a Sunday…
Hope the big grey boxy thing solves my problems and I can keep the other bits for just in case.
Post #724112 7th Sep 2025 3:56pm
All fatties are very susceptible to low volts.
Personally I have thrown away the old battery in every fatty I've owned, and fitted new (two in the 405..!)
Halfords, and other sites will tell you which one you need if you put your reg number in....
Then take it from there.... Thumbs Up Pete
-Click here for Thread-
Post #724113 7th Sep 2025 3:57pm
There is an explosive disconnect on the + side, there is a procedure for replacing the battery, you can find it in the workshop manual downloadable from the WIKI, link above right... Pete
Post #724114 7th Sep 2025 4:02pm
dingg1
Firstly change the battery, it's probably due a new one, type 019, go agm they last longer ime, you can squeeze a type 020 in but again imo better for an agm type 019.
Could be parasitic drain, but try a new battery first before you go down that rabbit hole.
Welcome to the pain (sorry bad joke) of a sc
Contrary to what some say, they really don't need a massive amount of outlay, but mine is starting to sound like triggers broom
Essentially if you can wield a spanner ok there's not much you can't do yourself
Good luck 👍
Post #724115 7th Sep 2025 4:10pm
Dick_
Thanks all
Reassured me I’m along the right lines.
I’ve rebuild defenders and discoverys quite extensively so relatively capable with a spanner.
I have a brand new 019 battery that I’ll try and switch out tomorrow and keep an eye on.
Fingers crossed it’s as easy as that as the one thing I loathe is electrical issues! Give me the agony inducing hard labour of technical mechanical fixes all day long - electricity is a dark art.
Post #724144 7th Sep 2025 9:26pm
Dick_
Just one further question right now:
Is an AGM battery going to provide me with any better performance over the 019 Yuasa I have ready to go in?
I’ve read a few comments that the L322 won’t charge the AGM battery properly, thus it’s a false economy - is this correct?
Has anyone else used a AGM battery successfully and noticed a positive improvement in battery health / life / performance etc?
Thanks
Post #724166 8th Sep 2025 10:08am
If it was me I'd use the one recommended, which is the one you have IIRC... Thumbs Up [/img] Pete
Post #724168 8th Sep 2025 10:23am
Dick_
Recommended battery fitted and car definitely started a lot quicker and with more conviction!
Obviously (stupidly) started it up and sat and played with the suspension and terrain settings while sat on the drive for 10 mins nicely chewing away at the battery while parked 😂
Initial tests after that seem positive - much more encouraging figures than the old battery was putting out. Will check again in the morning and see how bad the draw has been on a brand new battery.
Post #724198 8th Sep 2025 7:54pm
You can tell fatty it has a new battery with a diagnostic tool but it will learn on it's own, just takes a bit longer for it to sort itself out.
Give it a few days and see how it goes.... Thumbs Up
If you plan on keeping it and doing work yourself you need a GAP IID tool or similar... Thumbs Up Pete
Post #724199 8th Sep 2025 8:05pm
Dick_
Having had a Disco 3 for a few years, I can confirm a Gap IID tool was the first thing I bought as I was on the way home from picking up the car!
Thank you for all the help- will report back!
Post #724202 8th Sep 2025 8:22pm
Thumbs Up Bow down Thumbs Up Pete
Post #724205 8th Sep 2025 8:58pm
MR GLOVER
United Kingdom 2005 Range Rover Supercharged 4.2 SC V8 Buckingham Blue
am on the 2nd varta 12v 110ah 920 a have had no problems leaving car 2 or 3 wks no probs Thumbs Up
Post #724254 9th Sep 2025 8:39pm
