![]() | Home > Technical (L405) > front knuckle cracking |
| woodyrvf750 Member Since: 10 Jul 2023 Location: Stratford Upon Avon Posts: 43
You don't need crack detection spray to see that! |
How are you getting on "Robbie993"? As this is not a UK registered car I wonder if the UK recall applies, even though it is within the VIN range.. |
| Mikey Member Since: 10 Jan 2008 Location: Dundee Posts: 1884
So, the fix now, is to fit a clamp over the top of the knuckle, so you can't see if it's cracked |
| Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8822
Interesting, looks like it will be very close to the tyre.....
That looks like a very sexy clamp. I want one, or two..
| goldeneye32 Member Since: 10 Jan 2024 Location: Hampshire Posts: 107
I am an Engineer (Mech Design) and there are a couple of possibilities for the failure.
| GraemeS Member Since: 07 Mar 2015 Location: Wagga area Posts: 2776
That bracket won't strengthen the casting as when the break occurs the broken piece moves inwards which is why the crack can be seen. The bracket will only prevent a broken piece from falling out if the 5mm bolt and thin sections of bracket can be trusted to hold it in.
| JCW Member Since: 13 Apr 2013 Location: Cotswolds Posts: 961
This approach is reminiscent of the Defender front axle issue (failing weld) and eventual recall N706 which also involves fitment of two clamps to hold the axle together and stop the wheel detaching in the event of failure, opposed replacing the defective parts. Jonathan
| nicedayforit Member Since: 11 Jun 2011 Location: Beside the Solway Posts: 3988
So now the integrity of the whole knuckle joint relies on a 5 or 6mm bolt in shear. You couldn’t make it up. Given that fitting these will constitute a modification and you will be obliged to tell your insurers l wonder what their reaction will be. Imo JLR need to go back to basics and redesign the whole joint.
| Alistair Member Since: 11 Feb 2011 Location: Peterborough / Alicante / Andorra Posts: 8135
I wonder if they'll just post them out like they did with the sleeping batteries |
| mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 8000
| Inigo Member Since: 15 Jan 2014 Location: Kent Posts: 60
I noticed that Rangeroverworld offer an aftermarket solution that claims to fix this.
These new brackets from JLR are £221.37 each plus VAT so a total of £531.28
Nice one. Aftermarket knuckle def reads better……
