Home > Technical (L405) > front knuckle cracking
Page 54 of 57 <123 ... 5354 555657>
woodyrvf750
You don't need crack detection spray to see that!
Post #723930 4th Sep 2025 11:46am
Mike T
United Kingdom 2016 Range Rover Autobiography SDV8 Mariana Black
Hi all. I can add my 2016 car to this list of cracks. Fortunately it was a crack and not a failure! I regularly check both knuckles for these cracks with no sign of anything one month ago but on 19th August I spotted a crack on the nearside - these develop fast!
I contacted my local MD and was referred to JLR Customer Care as my car is outside of JLR's recall VIN range. JLR Customer Care opened a case and asked I book the car into my local MD for inspection. What JLR could not do was give me any assurances that this would be covered by the recall because the VIN is outside of the range, despite displaying the issue which prompted the recall....
In the meantime they wanted £240 to carry out the inspection and the car for two days. My issue is that the Range Rover is my only car and that I could not continue driving with the risk of a failure, obviously.
It was the lack of assurance that prompted me to replace the knuckle myself. The inspection cost alone goes a long way toward the cost of the knuckle.
I did the work myself and it is all pretty straightforward, with the correct tools, and I will also add that the driveshaft also needed replacement as was well and truly STUCK in the hub! 12 tons of vertical press could not even begin to persuade the two to part ways!
In the end I could have faced the cost of the inspection, knuckle and driveshaft plus LR's labour rates. I realise that I cannot expect JLR to help me further with this particular case but I do not have a full MD service history or warranty to jeopardise so the risk of the high cost made my mind up to resolve this myself.
I have also lodged a Vehicle Safety Defect Report with the DVSA. When I explained the steps I took to JLR Customer Care they did not seem surprised and reminded me that they may need to inspect the removed knuckle as part of the DVSA's investigation.
One final point. Ignoring the reasons for my own decision to avoid the risk of JLR not covering these costs I will say that dealing with JLR Customer Care has been a positive experience with responsive and polite staff answering my calls and emails.
Post #724224 9th Sep 2025 11:22am
woodyrvf750
Any progress with JLR Poland?
Robbie993 wrote:
oooooops... normally I like cracks.. but not this one!
noooo way I'm going on the Autobahn home with this. Left it at the dealer abroad, and took the plane home. They will let me know.... fingers crossed. By the way: 2015 and in the VIN range.
I checked last year, no crack, and now, this crack. It develops fast!
How are you getting on "Robbie993"? As this is not a UK registered car I wonder if the UK recall applies, even though it is within the VIN range..
Post #724236 9th Sep 2025 3:39pm
Mikey
So, the fix now, is to fit a clamp over the top of the knuckle, so you can't see if it's cracked Laughing
Post #724248 9th Sep 2025 6:57pm
Interesting, looks like it will be very close to the tyre.....
Not being on the list but with a 2014, do you know if you can you buy these and fit yourself to strengthen it up...? Pete
-Click here for Thread-
Post #724250 9th Sep 2025 8:07pm
woodyrvf750
That looks like a very sexy clamp. I want one, or two..
Surely the idea is to fit these clamps to knuckles that are not yet cracked.
This bracket may be designed to give the additional strength necessary to prevent future cracking. I see the date range is still 2014 to 2016. FFS.
I'm not an engineer, but this looks like recognition that the original knuckle design was just a bit crappy.
First person to post a photo of one of these beauties wins a tube of Smarties.
Post #724252 9th Sep 2025 8:15pm
goldeneye32
United Kingdom 2014 Range Rover Autobiography SDV8 Firenze Red
I am an Engineer (Mech Design) and there are a couple of possibilities for the failure.
As previously mentioned galvanic corrosion, or simply the incorrect grade of material was selected or no FEA was done on the component.
My car was registered in July of 24, so it falls outside the affected component assembly date from 01 Oct 2014 to 2016, one less thing to worry about!
Post #724256 9th Sep 2025 9:29pm
GraemeS
Australia
That bracket won't strengthen the casting as when the break occurs the broken piece moves inwards which is why the crack can be seen. The bracket will only prevent a broken piece from falling out if the 5mm bolt and thin sections of bracket can be trusted to hold it in.
Is it April 1st? L405 D350 SE Carpathian Grey D5 19" rims
Post #724260 9th Sep 2025 9:39pm
JCW
This approach is reminiscent of the Defender front axle issue (failing weld) and eventual recall N706 which also involves fitment of two clamps to hold the axle together and stop the wheel detaching in the event of failure, opposed replacing the defective parts. Jonathan
2010 L322 5.0 SC Autobiography Black
2007 Defender 90 XS Hardtop
Post #724261 9th Sep 2025 9:40pm
So now the integrity of the whole knuckle joint relies on a 5 or 6mm bolt in shear. You couldn’t make it up. Given that fitting these will constitute a modification and you will be obliged to tell your insurers l wonder what their reaction will be. Imo JLR need to go back to basics and redesign the whole joint.
Insurer, What’s the purpose of the modification.
You, To hide the crack that forms in the two front top knuckle joints so that when one fails it will stop the wheel flying off when I’m driving down the motorway at 70mph.
Post #724275 10th Sep 2025 8:47am
I wonder if they'll just post them out like they did with the sleeping batteries Laughing
For our foreign friends - it's also worth noting that the first image Mikey posted says Global Recall Action at the top right Thumbs Up
Post #724277 10th Sep 2025 9:54am
mjdronfield
 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #724306 10th Sep 2025 10:27pm
Inigo
United Kingdom 2019 Range Rover SVAutobiography 5.0 SC V8 Corris Grey
I noticed that Rangeroverworld offer an aftermarket solution that claims to fix this.
This might be an alternative for those of us with the same issue outside of the recall range. Does anyone have any experience?
Post #724307 10th Sep 2025 11:10pm
These new brackets from JLR are £221.37 each plus VAT so a total of £531.28
Hardly a cheap alternative...... Shocked Pete
Post #724309 11th Sep 2025 12:04am
mjdronfield
Nice one. Aftermarket knuckle def reads better……
https://rangeroverworld.co.uk/shop/ols/pro...ng-knuckle
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #724332 11th Sep 2025 12:07pm
