Home > Technical (L322) > Security upgrades for later L322's
JayGee
As I found out a few months ago the rolling code security system used by these fobs has now been cracked and readily available devices such as the Flipper zero can intercept your lock or open command and then access your car at will. Not much you can do to stop it happening but you are most at risk in public car parks where someone with one of these devices can be lurking nearby. I'm in a communal CP so have to assume my car is now compromised and accessible at anytime although I've been parked elsewhere (inconviniently but safe) for a while since the break-in a couple of months ago. My partial solution has been to replace the folding load cover with a solid one that can't be lifted up and a locking system on the rear seats so they can't be folded down. This combined with activating the Valet mode when parking effectivley makes the boot pretty secure. Next vunerability is to actual drive away theft via key creation with the OBD port so I've moved this and blanked the port under the dash. It would need a lot of effort to get at the cable and even if they did I put a kill switch on it ( also means I can have my GAP IID permenantly attached but powerd off). Being particularly paranoid and thinking whoever accessed it may have already created a spare key I also put a kill switch on the gear control module and topped this off with a stoplock pro elite on the steering wheel. Apart from making the solid load cover it was pretty easy DIY although a bit fiddly.
 2012 TDV8 Vogue (L322)
Post #724550 14th Sep 2025 7:16pm
Should stay where you leave it.... Thumbs Up Bow down Thumbs Up Pete
-Click here for Thread-
Post #724553 14th Sep 2025 7:31pm
Daniel O Donnell
I was thinking of getting a cutoff switch put on mine. Just to be a deterrent should someone overcome the immobiliser.
The solid parcel shelf wouldn’t work for me, I use the fold up all the time. I was thinking that the cutoff would go to the fuel pump, but if the gear control modular is easier, that might be a better bet.
Post #724658 16th Sep 2025 11:59pm
JayGee
The solid load cover takes a bit of getting used to but not found it a major inconvenience and well worth the trade off for the security. It is removable as are the seat locks from inside the boot should I need to use it for moving bulky items. I had considered a switch on the fuel lift pump on the tank but was worried of fuel starvation to the HP pump should someone try to start it so opted for the gear control module which was also easier to implement. 2012 TDV8 Vogue (L322)
Post #724659 17th Sep 2025 7:42am
Rambles
2011 Range Rover Vogue SE TDV8 Stornoway Grey
Maybe use the key rather than the fob in public areas like car parks
I had not heard that later model L322s were now security compromised
Except for parts, why would someone want to steal 15+ year old FFRRs?
Post #724686 17th Sep 2025 4:19pm
JayGee
Not sure the alarm or superlock is enabled with the key? Plenty of reasons to steal an old 4x4 such as use in crime, just because they can and for the hell of it esp if it's now quick and easy to do. 2012 TDV8 Vogue (L322)
Post #724689 17th Sep 2025 4:50pm
Ian Thompson
Correct JayGee, neither of those are active when using the manual key, plus you have to lock all other doors manually with the button and the boot operation is also compromised 2011 4.4 TDV8 Vogue Santorini Black with black interior and glass
2004 TD5 Discovery 2 - gone
2002 Freelander 1.8 - gone
Post #725076 25th Sep 2025 1:00pm
GGDR
I am not sure L322s are on the hot-to-steal list.
But I do know a lot of cars get broken into due to laptops in the boot
laptops in sleep mode can be detected. Affects all cars obvs.
near me, by the gym a lot of this is happening. Cheers, Greg
Post #725133 26th Sep 2025 9:53am
JayGee
It’s the ease with which it can be done these days that’s the problem as I found out when mine was broken into. Previously a thief would have to smash glass which would be a kind of deterrent in itself unless there was something of value on obvious display worth the risk but now a silent entry is possible so it’s no risk to have a rummage about even for lowish value items. 2012 TDV8 Vogue (L322)
Post #725134 26th Sep 2025 10:14am
