![]() | Home > Technical (L322) > Security upgrades for later L322's |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8815 ![]() ![]() ![]() |
Should stay where you leave it.... |
Daniel O Donnell Member Since: 05 Jul 2024 Location: Hampshire Posts: 5 ![]() |
I was thinking of getting a cutoff switch put on mine. Just to be a deterrent should someone overcome the immobiliser.
JayGee Member Since: 27 Jul 2021 Location: London Posts: 3345 ![]() ![]() ![]() |
The solid load cover takes a bit of getting used to but not found it a major inconvenience and well worth the trade off for the security. It is removable as are the seat locks from inside the boot should I need to use it for moving bulky items. I had considered a switch on the fuel lift pump on the tank but was worried of fuel starvation to the HP pump should someone try to start it so opted for the gear control module which was also easier to implement. 2012 TDV8 Vogue (L322) |
Rambles Member Since: 16 Apr 2011 Location: UK Posts: 847 ![]() ![]() |
Maybe use the key rather than the fob in public areas like car parks
Not sure the alarm or superlock is enabled with the key? Plenty of reasons to steal an old 4x4 such as use in crime, just because they can and for the hell of it esp if it's now quick and easy to do. 2012 TDV8 Vogue (L322) |
