Home > My Range Rover > L322 5.0 autobiography Sumatra Black - ownership journey
Page 7 of 8 <12345678>
theJAFman
United Kingdom 2010 Range Rover Autobiography 5.0 SC V8 Baltic Blue
Thanks option 2 it is!
Post #724674 17th Sep 2025 1:30pm
theJAFman
Replaced broken speakers today overall much better and cleaner as expected
Last boost in quality will come from new head unit
With the speakers sorted this car only has 2 issues left
1. Ac leak - braze weld repair awaits
2. Map lights on ride side have a ground issue and do not illuminate when pressed both front and rear so they must share a common point I will likely ignore this hope to rectify it by accident somehow doing somthing else at some point
Girly touch is settled i could not find pink valve necks
Soldered cars connector to new speaker terminals
Added some dynamatt like stuff best i could
Post #724709 17th Sep 2025 9:22pm
theJAFman
The dreaded ac pipe repair
This car has 4 way ac so this pipe splits up in the bulkhead
One junction was completely inaccessible despite scratching my head for an hour with a borescope. The only access would be from below after removing downpipes.....
Nah eff that, inspired from another fullfat member i decided to cut a section away and pull the offending peice from the cut to condenser.
Having stared at the pipe the holes were too big to reliably try a brazing rod
I then spent the best part of the morning bending 10mm copper pipe with a old brake pipe bender that accepts 10mm
End results as follows oem bends and fitting bar the copper and compression joints
Testing awaits but should be ayt
Post #724739 18th Sep 2025 2:21pm
Gsxr1250dave
That will do the job nicely 👌 it's how I fix all of mine. It took 2 attemps to fill with gas only because the valve in the ac pump was stuck due to it being out of service for so long. Vacced out the 1st attempt via the machine yhen on yhe end attempt refilled in minutes.
Still ice cold Thumbs Up
Post #724752 18th Sep 2025 6:10pm
theJAFman
Thanks Dave you are now my Ac repair hero!
Post #724766 18th Sep 2025 9:15pm
theJAFman
The love continues
Full drivers side and bootlid paint corrected and sealed
Fitted some chinese led replacements for the xenon and hi beam
This brand has been tested by some Russian engineer on youtube and it outputs much more light consistently
The paint came out amazing for some shed man elbow grease only one side to go and whole car is done bar the roof but not polishing or correcting that
I have to wait till tomorrow to test the new lights which im bizzarely excited about
Post #724830 19th Sep 2025 11:58pm
rvbush
United Kingdom 2011 Range Rover Vogue TDV8 Stornoway Grey
They're the bulbs I've used, brilliant!! Drives:
2010 FFRR TdV8 Vogue - Stornoway Grey
2010 FFRR TdV8 Vogue SE - Zermatt Silver
1998 BMW E36 M3 GTII
Post #724834 20th Sep 2025 11:08am
theJAFman
Fantastic
Did you find them noticably brighter in use?
Post #724836 20th Sep 2025 11:21am
rvbush
Yes, very!! And, if anything, the beam pattern is sharper. Drives:
Post #724870 21st Sep 2025 8:29am
kevinp
Yes, best upgrade I've done to my car. Incredible difference. Thumbs Up
Post #724874 21st Sep 2025 9:53am
theJAFman
Thanks guys
Having had a little drive last light
Low beams are noticeably brighter
The highbeams which work in tandem with low beam bi xenon setting is stupid bright!
Post #724875 21st Sep 2025 10:15am
theJAFman
Went to try get ac filled today
Car wouldn't maintain enough vaccum pressure
I think its meant to reach around negative 2 bar mine plataued at 0.87 for about 9 mins so i guess i try nip up all joints a bit more bought a 17mm stubby for this job alone or maybe i need higher quality joints 😔
Post #724910 22nd Sep 2025 11:32am
Gsxr1250dave
If you have a small air tank/compressor you can track down leaks using compressed air in the system. I made a small attachment up so i could fill the ac with good old air which helped me find my leak.
You may also need to nip up those compression fittings, did you use any jointy compound on those olives ? When you fitted them.
Post #724937 22nd Sep 2025 6:21pm
theJAFman
I have a fair sized air compressor i couldnt think of relevent fittings to adapt to test the line myself like this
No jointy compound as i cant imagine jointy compound resisting ac line high pressure like 200 psi as water pressure would be much lower
Maybe somthing like this to air quick connects?
https://amzn.eu/d/eLnjT1F
Post #724939 22nd Sep 2025 6:25pm
Gsxr1250dave
I always use fernox hawk white in my fittings it's rated for 5 bar for gas and 7 bar for water the actual fittings are rated at over 200 psi from memory and 10mm copper pipe over 1000 psi so either the fittings are not nipped up enuff or there is another leak.
You could use those and modify it to run low pressure air into the ac system you don't need a lot of pressure to fault find. I had a fuel pressure testing kit sitting on the shelf I used a fitting from that a bit of rubber hose and hey presto.
Post #724941 22nd Sep 2025 6:52pm
