![]() | Home > My Range Rover > L322 5.0 autobiography Sumatra Black - ownership journey |
pcourtney Member Since: 14 Jan 2020 Location: Stansted Posts: 1024 ![]() ![]() ![]() |
what a special service you have given the old girl there, much respect from me also |
theJAFman Member Since: 02 Aug 2025 Location: London Posts: 107 ![]() ![]() ![]() |
Thanks mate its getting there !
dhallworth Member Since: 10 Oct 2011 Location: Glasgow Posts: 3346 ![]() ![]() ![]() |
The instructions in the manual say that you need to hold the revs at 2k rpm or something like that whilst bleeding. It's been a while since I did mine. I followed the manual but didn't have any issues bleeding it.
Thanks david, where can i find this manual, surely you dont mean the book itself? |
Rackers Member Since: 04 Apr 2022 Location: Portsmouth Posts: 100 ![]() ![]() ![]() |
I had to use a vacuum purge & refill kit to successfully bleed my 5.0. Tried and tried with the bleed ports but these things are a notorious PITA to bleed manually. |
Apologies, the workshop manual. I'll try and find it just now. 2002 4.6 Vogue SE - Alveston Red with Lightstone Leather
Thank you that would be amazing |
I've managed to get the cooling system bleeding instructions from the entire workshop manual into a 4 page document. Here's the instructions:
Thank u soo much that looks like different car but i just found a working link to procedures!
Edit that is the expansion tank
Here goes nothing |
Same result with rear remaining cold and car starts to overheat
Car is now fully bled all 4 zones primed with hot air. I needed quite the incline to get the air out
Guys any idea where this green plug goes? Im guessing its somthing do with factory audio
