![]() | Home > My Range Rover > L322 5.0 autobiography Sumatra Black - ownership journey |
theJAFman Member Since: 02 Aug 2025 Location: London Posts: 101 ![]() ![]() ![]() |
Thanks option 2 it is! |
The dreaded ac pipe repair
Gsxr1250dave Member Since: 20 Oct 2018 Location: London Posts: 1051 ![]() ![]() |
That will do the job nicely 👌 it's how I fix all of mine. It took 2 attemps to fill with gas only because the valve in the ac pump was stuck due to it being out of service for so long. Vacced out the 1st attempt via the machine yhen on yhe end attempt refilled in minutes.
Thanks Dave you are now my Ac repair hero! |
The love continues
rvbush Member Since: 08 Jan 2016 Location: Leamington Spa Posts: 564 ![]() ![]() ![]() |
They're the bulbs I've used, brilliant!! Drives:
Fantastic
Yes, very!! And, if anything, the beam pattern is sharper. Drives:
kevinp Member Since: 28 Sep 2019 Location: Telford Posts: 1357 ![]() ![]() ![]() |
Yes, best upgrade I've done to my car. Incredible difference. |
Thanks guys
Went to try get ac filled today
If you have a small air tank/compressor you can track down leaks using compressed air in the system. I made a small attachment up so i could fill the ac with good old air which helped me find my leak.
I have a fair sized air compressor i couldnt think of relevent fittings to adapt to test the line myself like this
I always use fernox hawk white in my fittings it's rated for 5 bar for gas and 7 bar for water the actual fittings are rated at over 200 psi from memory and 10mm copper pipe over 1000 psi so either the fittings are not nipped up enuff or there is another leak.
