Home > Maintenance & Mods (L322) > L322 as a commercial vehicle
Marto
Has anyone "converted" their L322 to a commercial vehicle - is it cheaper to tax and insure as a commercial vehicle?
I guess some kind of divider behind the front seats would be needed
Interested to hear if this is commonly done[/b]
Post #724759 18th Sep 2025 7:47pm
chugga90
It would need to be classified as a commercial vehicle before getting the relevant rfl, can imagine convincing the insurer that it’s a commercial will also be an effort.
Good luck with your project
Post #724760 18th Sep 2025 7:56pm
Red Hot one
United Kingdom 2009 Range Rover Vogue TDV8 Stornoway Grey
We use our L322 3.6 as a farm vehicle, not registered as a commercial, just put it down as a Landrover for the accountant.. Whistle I doubt you can retrospectively register the vehicle as a commercial, I'm sure HMRC will make it as difficult as possible, but as far as I know the vehicle has to be registered as a commercial when newly registered but do correct me if I'm wrong.
Will
Post #724818 19th Sep 2025 7:27pm
Monty400k
Scotland 2002 Range Rover SE Td6 Zermatt Silver
I use mine with the back seats removed and a slider with Milwaukee packout mounts, had considered adapting a discovery 5 commercial load liner and bulkhead as they are cheap second hand, hadn't considered trying to get it registered as a commercial
Post #724819 19th Sep 2025 7:47pm
Marto
Hi Monty400k - thanks for sharing - do you have a photo of the loading bay and the mountings you used?
PS loving those wheels
Post #724828 19th Sep 2025 10:21pm
Monty400k
Post #725285 28th Sep 2025 7:09pm
Monty400k
I used a pull out designed for a king cab and Hilux
Post #725286 28th Sep 2025 7:10pm
this might help,
https://www.fullfatrr.com/forum/topic52925...rcial+l322 ... - .- -.
Post #725293 28th Sep 2025 8:08pm
JMC
Scotland 2012 Range Rover Westminster TDV8 Orkney Grey
My first L322 (3.6TDV8) was converted to a commercial when new at first registration. Rear seats and belts removed, shear bolts in the mounting points for the rear seats and belts, rear windows blacked out, metal divider between front and rear seats, etc.
Yes, it was a bit of a tax (VAT) dodge, but when I applied for commercial VED status it was refused - they said it had to be a commercial from the production line, not converted by the dealer (as mine was).
Probably just as well, as it would have meant I'd have been speeding all the time! Whistle
 The older I get, the more I realise that people confuse wrinkles for wisdom Smile
Post #725313 29th Sep 2025 9:33am
Monty400k
Don't suppose you know what the bulkhead came out of, looks as though it's been adapted to fit the L322?
Post #725314 29th Sep 2025 10:02am
JMC
I'm afraid I don't, but suspect it's a modified D3 or L322 full height dog guard. The older I get, the more I realise that people confuse wrinkles for wisdom Smile
Post #725341 29th Sep 2025 3:29pm
