Home > Technical (L405) > New engine require 4.4 sdv8
Page 3 of 3 <123
William97841
From the cylinders
Post #725378 29th Sep 2025 9:21pm
4RRS
United Kingdom 2016 Range Rover SVAutobiography SDV8 Corris Grey
Definitely injectors out then to clear it. L405 SV Autobiography LWB SDV8, finished in Aston Martin China Grey by ETO division.
Post #725379 29th Sep 2025 9:21pm
William97841
Yh definitely they look fun to come out lol. I think (hoping) it’s only 2 cylinders it’s affected but going to take them all out and check
Post #725380 29th Sep 2025 9:23pm
4RRS
Should just pull out without needing a removal tool, mine were a doddle at 160k miles. L405 SV Autobiography LWB SDV8, finished in Aston Martin China Grey by ETO division.
Post #725382 29th Sep 2025 9:30pm
William97841
Got all 8 injectors…number had some oil but enough when I turned the crank it shot out and number 3 had a little bit. Number had just about as well but 8 was the worst. The crank is free but I was going to remove the fuse for the fuel and get the starter motor move some more out but have no clue what fuse number it is. Any one know?
Any other ideas on how to remove the little bits of oil as well?
Thanls
Post #725435 30th Sep 2025 5:47pm
William97841
Also the clip has the rubber grommet on it doesn’t look great. If that wasn’t the cause of the oil escaping where else can it come from??
Post #725438 30th Sep 2025 6:28pm
4RRS
I'd say the only other source for that amount of oil would be either of the turbos, maybe worth disconnetcing the intercooler hoses as close to the turbos as possible and spinning it over without the injectors in and see if you have any oil appearing from either of them.
Did you check the air filters for oil? L405 SV Autobiography LWB SDV8, finished in Aston Martin China Grey by ETO division.
Post #725463 1st Oct 2025 8:54am
4RRS
Thanls
According to the wiring diagram, Junction box rear, either mini relay 13R or 15A fuse 6R L405 SV Autobiography LWB SDV8, finished in Aston Martin China Grey by ETO division.
Post #725464 1st Oct 2025 9:03am
William97841
The saga continues checked the air filters are clean no oil only was in the last injectors. I don’t think it was the turbos I had a look at the bung in the oil filter housing and an see oil gone down that small air hole so I’m thinking that’s where the oil came down butttt now another problem tried the starter motor and guess what it’s just clicks so going to take that out…Christ knows why that’s gone but now it just clicks. Working fine before. Can this get any worst!
Post #725513 2nd Oct 2025 7:00pm
Kiwi RR
New Zealand 2014 Range Rover HSE SDV8 Fuji White
I had oil misbehaving after my rebuilt engine was started. It was coming out of the exhaust owing to a bung at the bottom of the turbo core being left in by my mechanic. I located the issue simply by parting the exhaust flange nearest both of the turbos by about 15mm, running the engine and saw oil coming out of the left hand one. It's about a 30 minute job - could be a quick way to eliminate the turbo cores as being the oil source?
Post #725878 8th Oct 2025 9:36pm
William97841
Right I’m back thanks kiwi rr it’s similar but found my problem.
So cleared the oil out from the bores put it all back fresh oil 9 litres of it. Found my mega blow fuse blown so had to replace that as well. Cranking and started. But I thought I’m gonna disconnected both turbos pipes clear the intercooler and hoses and then found the drivers side turbo (secondary turbo I think) Censored oil out for fun when running. So question is now why did it fail so going going to check the dpf limit and then 2nd how to replace the bloody thing??? Any replaced it when engine in place?
Post #726219 15th Oct 2025 5:04pm
4RRS
Drivers side is the primary turbo I seem to remember. I'd be having words with the supplier if they were remanufactured!!
Not a nice job in situ, but it can be done, fortunately I've never had to!!
Sounds like you hopefully caught it before any major damage was done. I'd certainly be less than impressed with the turbo supplier, surely some financial assistance is in order?
Keep us posted. L405 SV Autobiography LWB SDV8, finished in Aston Martin China Grey by ETO division.
Post #726221 15th Oct 2025 5:30pm
William97841
Yes definitely gonna be ringing them tomorrow.
I’m not looking forward to it as it was a bit of a pain when outside can only imagine the cuts I’m gonna get.
My worry is could the dpf be blocked but have just checked and it’s level is DIESEL PARTICULARE FILTER REMAINING VOLUME 0L
And dpf soot concentration 20 g/m3
Which I think is clean???
Can only think it’s a bad turbo??
Post #726227 15th Oct 2025 7:28pm
William97841
How to unload a pic?
Post #726228 15th Oct 2025 7:29pm
Kiwi RR
I'm about to work with my mechanic on replacing both turbos with aftermarket units. Service manual says it can be done although at one point requires lifting the engine up while it is still attached to its mounts. Will be doing it in the next week so happy to post progress if you've not already cracked into it. If it were me I think I would do engine out but my skills with nuts and bolts are no where near my mechanic. I do also remember that you have to take out the fans, the alternator and starter motor before you can get to the RHS turbo - first two can be a bit of a mission from memory.
I think for posting pictures you just click the choose photos button under the text entry when replying and select from a folder on you computer?
Post #726243 16th Oct 2025 2:43am
Page 3 of 3 <123
