Home > In Car Electronics (L322) > DAB radio module
Page 3 of 3 <123
barbel jim
Different types of dab…… they introduced dab+ to enable more channels. The l322 unit only supports dab, hence why people change the dab module to the latter version. You can stream via Bluetooth and you phone, but still need data and an app. Swapping the dab module to dab+ is simple and probably £120 all in. It has its quirks turning on and off, but you can get alot more chanels, and everything else works as it should
Post #725574 3rd Oct 2025 9:56pm
AndyRoo
Scotland 2012 Range Rover Westminster TDV8 Fuji White
Many thanks, I'll look into that idea.
Cheers, Andy Fuji White / Jet 2012 4.4 TDV8 Westminster
Post #725580 4th Oct 2025 7:25am
Jimnic007
United Kingdom 2012 Range Rover Vogue TDV8 Nara Bronze
Hi Jonny,
Do you need to do this every time you want to select DAB+ or just after the first time of installing?
Thanks,
JonnyCJ wrote:
ashtrucker wrote:
Didn’t think you could add DAB+ to l322
You can - with an adapter cable. The only thing you need to do to get it to function is to select DAB on the head unit, switch the display off then on and then turn the volume knob. I did it on my old L320 and it worked fine and lots of other L320 owners have done the same.
Post #726154 14th Oct 2025 3:23pm
barbel jim
From my experience every time you go back to dab +…..
Something to do with the software compatibility, but totally worth it imo
Post #726161 14th Oct 2025 6:07pm
Jimnic007
Thanks Jim,
I have ordered a DAB+ module and the Jaguar plug, so hopefully it will all work and I will be able to listen to DAB stations again!
Thanks all
Post #726184 15th Oct 2025 7:22am
barbel jim
The most fiddly bit is bolting the new module back in. I ordered a jag plug with tails, then cut the old plug off with 50mm tail and crimped the new one on. Relatively simple to revert back if ever needed. Best mod ever for a l322 Mr. Green
Post #726194 15th Oct 2025 8:51am
Jimnic007
Before I disconnect anything, do I need to disconnect the battery or take any other precautions, so that I don't blow anything up??
Thanks
James
Post #726231 15th Oct 2025 6:49pm
barbel jim
No need to disconnect battery…. They’ll be fuse protection. Make sure the ignition is off and just cut the wires one at a time, and keep away from metal, the red positive especially Laughing worse case you’ll blow a fuse
Post #726235 15th Oct 2025 8:34pm
JonnyCJ
United Kingdom 2012 Range Rover Vogue SE 4.4 V8 Sumatra Black
Did you get sorted James ? You can actually select DAB+ by selecting it from the head unit and then just using the volume button either way to engage it. Doesn't show the station list on the head unit though - you need to do the on/off trick first, or alternatively just leave it in DAB+ all the time.
Either way, it's a fiddly inconvenience compared to having DAB+
Post #727039 28th Oct 2025 10:49am
Jimnic007
Thanks,
I did get it installed, only losing a few bits of skin from the knuckles and back of my right hand! It is located right down in the well at the rear.
All went well and I now get all of the stations I want, but it is strange to have to turn the unit off/on and then change the volume to get it working. I will take a look at your suggestion.
One thing I have noticed, is that the radio now stays on after I turn the car off/close the door and only goes off after a few of seconds locking the car??
Post #727046 28th Oct 2025 12:37pm
JonnyCJ
Yep - everything you've said is par for the course !
The DAB sometimes stays on, sometimes goes off, but if you lock the car it goes off. Call it a handy reminder to lock it.
As for why you have to do the knob twiddling to engage the DAB+ - it's because the L322 system wasn't designed for a DAB+ so it's just fortunate it works as well as it does.
Post #727049 28th Oct 2025 12:49pm
Page 3 of 3 <123
