![]() | Home > Technical (L322) > paddling pool around the compressor in boot !!!!! Help !! :( |
Where the plastic pipe meets the metal part you need to push the collet in towards the metal part and pull the plastic pipe out. Use a small open ended spanner on the collet to give you more leverage |
RR8701 Member Since: 11 Aug 2011 Location: East Ayrshire Posts: 380 ![]() ![]() ![]() |
hi mate, i actually literally just managed to figure that out, ive got it in the house and infront of a halogen heater, any other advise on "fixing it" besides blow drying it and heating it |
Give it plenty time to dry out |
Rob2529 Member Since: 22 Nov 2010 Location: Wirral, uk Posts: 1470 ![]() ![]() ![]() |
I would do the same. Plenty of time to dry. You could put 12v across it to get it pumping to make sure it's clear. If not don't worry. [img]http://www.fuelly.com/driver/rob2529/range-rover[img/]
Can I ask a really dumb question how would i put a "12v across it" |
You need to determine what is the positive and negative connections on the multi-plug connected to the compressor and then connect them to a battery |
One thing keeps coming to mind, i have seen a few posts where people say there is sometimes a problem with the actual release value and i would imagine this is the brass cylinder that is in my pics at the end of the air pipe.
Once you have the compressor refitted and working leave the rear tyre cover off and try lowering the suspension, you should hear the valve dumping the excess pressure if it is working properly |
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6424 ![]() ![]() |
Just looking at the electrical workshop manual seems the Red/Yellow wire (1) heads off to the Rear Fusebox - live feed (Fuse 18/88 ) Brown/Yellow (6) goes to the Header-Earth - earth All the other wires talk to the Air Suspension ECU Maybe someone can confirm, and please check this out and don't take my word for it before trying the compressor on a 12v supply ![]() Experience is the only genuine knowledge, but as time passes, I have forgotten more than I can remember ![]() Volvo V70 P2 2006 2.4 Petrol 170bhp Estate SE MG Midget Mk1 1962 Previous: L322 Range Rover TDV8 3.6 2008; L322 Range Rover TD6 3.0 2002; P38A Range Rover V8 1999 Last edited by Joe90 on 8th Oct 2011 6:19pm. Edited 1 time in total |
i really am at my wits end with this, i put the compressor back in, dried it all out, i even left the heater in the car for one hour, dried it all with a tissue, the connections too and i turned engine on, went for a drive and still nothing, the compressor doesnt even make a peep of noise.
Hi Joe, yeah i had a look at the connections and there are two really thick wires and the rest are small hence i gathered they would be the electrical feeds etc problem i have is that i dont have a 12v supply. i was actually thinking i would cut my car charger and run a 12v off my other car and try and touch the two wires on the compressor connection like that..... hope that makes sense. |
Hi joe,
Guys, is the fuse in the back or the front of the car for the compressor ?
