Home > Technical (L322) > paddling pool around the compressor in boot !!!!! Help !! :(
Page 3 of 6 <123456>
RR8701
United Kingdom 2005 Range Rover Vogue 4.4 V8 Java Black
Update:
Well guys, determind not to let this get to me, i went back out to the car turned it on and done the lock to lock to reset the angle sensors i beleive.
low and behold i can here the compressor come on for maybe 10 seconds or so and the heard the RV do the dump valve noise 2 or 3 times but then it stops.
turned the engine on and off again, lock to lock and compressor comes on again, dump valve noise twice and stops again....
that shows me possibly that both things are working but what could be stopping the car system from just continuing to use the EAS compressor etc and work as normal...
i have to say the compressor is rather loud however there is no tyre, boot cover, rear seats or parcel shelf blocked the noise hence why it might just seem like that to me, i took everything out with the rear seats folded.
Post #86016 8th Oct 2011 12:17pm
You should be able to hear the compressor, but it should not be too loud.
Post #86019 8th Oct 2011 12:23pm
the compressor should only run for a short time intermitantly. If you have no air suspension fault on the dash its ok. drop the car to access height then raise it to offroad. that will make the compressor run for longer if your concerned. [img]http://www.fuelly.com/driver/rob2529/range-rover[img/]
Post #86023 8th Oct 2011 12:37pm
RR8701
Hi 47p2,
I was out again and as soon as i do the lock the lock thing it starts working, its not so loud now, just normal tbh from my own estimate.
but it just stopped after releasing some pressure. not sure what course of action i should take now tbh. just out of curiosity i went out the the car and the distance from the bottom of my alloys to the middle arch point are all different:
front left: 32cm
front right: 31cm
rear left: 31cm
rear right: 30.5cm
is it possible to have this much difference? is it normal or is this way off ?
if my compressor and release valve starts each time i do the lock to lock it shows me it 100% works, the process is working. even when i was sat in the car i could feel it adjusting the corners while the compressor was on but it always stops working after the exact same amount of time, what would this show??
could it mean its working fine as i dont suspect that the compressor runs 24 7 however the gremlin within the car has a stored fault and its to be reset or could it be the compressor is still screwed, and to test it i should hook it up to a 12v from my other car and see if it runs for more than 30 seconds????>
Post #86025 8th Oct 2011 12:38pm
RR8701
hi rob, the trouble is the workings of the compressor and valve seem to be ok to me, however the inactive air susp fault on dash is still there and the suspension settings are locked to normal and its not changing at all no matter. what i do. any suggestions.
Post #86028 8th Oct 2011 12:46pm
You could try disconnecting the battery for 20 minutes (both leads then connect a wire between the two leads once removed from the battery) (do not connect a wire between the two battery terminals) to see if that clears any faults, otherwise it might be a trip to an indie to have the fault codes read and re-set and take it from there
Post #86045 8th Oct 2011 1:58pm
RR8701
I was hoping you wouldnt say that, started the car again, release value came on, all hieghts sitting an 30cm from bottom of rim to arch so i can eleminate a sensor error. clearly it works fine and is keeping the car at a good height.
i did disconnect the battery right now but only the negative. ill disconnect both, and then touch a wire between the two wires i take off the terminals ?
ill do that now, actually my car bosch battery just came from euro car parts. going to pump that in while im there.
Post #86047 8th Oct 2011 2:13pm
Leave it disconnected for 20mins or so with the wire attached to the two leads. Re-connect the positive lead first then the neg, start the engine and turn the steering lock to lock to allow the steering position to be recognised by the computer and see how it goes from there
Post #86048 8th Oct 2011 2:17pm
RR8701 wrote:
Hi joe,
i assume that is a rave manual you have that you have uploaded a screen shot of, where did you get that from if you dont mind me asking, looks quite good. haha.
thanks
Here's a link to the workshop manual (copy and paste whole link)
http://www.landroverweb.com/Pdf-files/Manuals/Workshop%20Manual%20L322%20Range%20Rover.pdf
And the electrical workshop manual for the wiki (Stan!!)
File name: ellm024e.pdf File size: 39.31 MB .
Post #86086 8th Oct 2011 6:25pm
all the downloads are in the wiki.. Thumbs Up ... - .- -.
Post #86089 8th Oct 2011 6:31pm
BrianC
on my 2005 model the compressor ecu is behind the dash next to the glovebox. I actually left a can of juice in the cupholder and it was very cold one day and the can exploded resulting in the ecu got covered in cola!.Worth checking the ecu is looking ok
Post #86099 8th Oct 2011 7:05pm
RR8701
Hi Mate,
what would this actually do, sorry just learning from all this too. so if i do the following procedure,
disconnet battery
get any wire and connect it from the positive to the negative battery terminal connector wires
then attached the +ve wire first to the battery, then the -ve to the battery
start engine
lock to lock within first 20 seconds and then see what happens ?
Thanks
Post #86172 9th Oct 2011 10:36am
It's supposed to clear any glitches in the ECUs'
I doubt if it will clear any fault codes but I've seen it done numerous times in LR indies
Post #86182 9th Oct 2011 11:00am
RR8701
Thanks mate, ill give that a try soon, can you recommend a good indy near glasgow if it doesnt work, since you are also in glasgow you might know someone who wont cost me an arm and a leg, im tempted to just buy the rsw all comms tool to clear the faults... lets just say, i dont think this is the last time i will see faults with my rr lol
Post #86185 9th Oct 2011 11:08am
It's all good and fine to clear the faults, but you need to find what's causing them and repair or they will just keep coming back. If the faults are not repaired they eventually go into a hard fault code where it can become expensive.
I used E.S. Alternators in Kirkintilloch a couple of weeks ago and they were very good
You can read about imy experiences here
Post #86197 9th Oct 2011 12:34pm
