![]() | Home > Technical (L322) > paddling pool around the compressor in boot !!!!! Help !! :( |
You should be able to hear the compressor, but it should not be too loud. |
Rob2529 Member Since: 22 Nov 2010 Location: Wirral, uk Posts: 1470 ![]() ![]() ![]() |
the compressor should only run for a short time intermitantly. If you have no air suspension fault on the dash its ok. drop the car to access height then raise it to offroad. that will make the compressor run for longer if your concerned. [img]http://www.fuelly.com/driver/rob2529/range-rover[img/]
RR8701 Member Since: 11 Aug 2011 Location: East Ayrshire Posts: 380 ![]() ![]() ![]() |
Hi 47p2,
hi rob, the trouble is the workings of the compressor and valve seem to be ok to me, however the inactive air susp fault on dash is still there and the suspension settings are locked to normal and its not changing at all no matter. what i do. any suggestions. |
You could try disconnecting the battery for 20 minutes (both leads then connect a wire between the two leads once removed from the battery) (do not connect a wire between the two battery terminals) to see if that clears any faults, otherwise it might be a trip to an indie to have the fault codes read and re-set and take it from there |
I was hoping you wouldnt say that, started the car again, release value came on, all hieghts sitting an 30cm from bottom of rim to arch so i can eleminate a sensor error. clearly it works fine and is keeping the car at a good height. i did disconnect the battery right now but only the negative. ill disconnect both, and then touch a wire between the two wires i take off the terminals ? ill do that now, actually my car bosch battery just came from euro car parts. going to pump that in while im there. |
Leave it disconnected for 20mins or so with the wire attached to the two leads. Re-connect the positive lead first then the neg, start the engine and turn the steering lock to lock to allow the steering position to be recognised by the computer and see how it goes from there |
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6424 ![]() ![]() |
Here's a link to the workshop manual (copy and paste whole link) http://www.landroverweb.com/Pdf-files/Manuals/Workshop%20Manual%20L322%20Range%20Rover.pdf
And the electrical workshop manual for the wiki (Stan!!) File name: ellm024e.pdf File size: 39.31 MB . Experience is the only genuine knowledge, but as time passes, I have forgotten more than I can remember ![]() Volvo V70 P2 2006 2.4 Petrol 170bhp Estate SE MG Midget Mk1 1962 Previous: L322 Range Rover TDV8 3.6 2008; L322 Range Rover TD6 3.0 2002; P38A Range Rover V8 1999 Last edited by Joe90 on 8th Oct 2011 6:49pm. Edited 1 time in total |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35781 ![]() ![]() |
all the downloads are in the wiki.. |
BrianC Member Since: 15 Apr 2009 Location: central belt Posts: 1429 ![]() ![]() |
on my 2005 model the compressor ecu is behind the dash next to the glovebox. I actually left a can of juice in the cupholder and it was very cold one day and the can exploded resulting in the ecu got covered in cola!.Worth checking the ecu is looking ok |
Hi Mate, what would this actually do, sorry just learning from all this too. so if i do the following procedure, disconnet battery get any wire and connect it from the positive to the negative battery terminal connector wires then attached the +ve wire first to the battery, then the -ve to the battery start engine lock to lock within first 20 seconds and then see what happens ? Thanks |
It's supposed to clear any glitches in the ECUs'
It's all good and fine to clear the faults, but you need to find what's causing them and repair or they will just keep coming back. If the faults are not repaired they eventually go into a hard fault code where it can become expensive.
