![]() | Home > Technical (L322) > Removing tow bar with no key? |
I know when I had a Disco there was a way to remove towbar without key! Just wondering if towbar on FFRR can be removed without key as the one i received with mine has been lost ! Obviously im concious there maybe crooks about so if possible please can you PM me . Thanks |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35858 ![]() ![]() |
best way is to undo the bolt which holds the 2 pieces and then you're left with a 2'' square hole..... ... - .- -.
TheAllSeeingPie Member Since: 18 Apr 2012 Location: Leeds Posts: 848 ![]() ![]() ![]() |
If it's the detachable towbar then you're best keeping it in the boot when not in use. Mine came with a broken key in the lock so I just removed it myself using rudimentary tools in not very long at all. Shame I can't get a replacement lock ... |
Knips Member Since: 01 Oct 2011 Location: United Kingdom Posts: 70 ![]() ![]() ![]() |
I have a similar issue with the key snapped off in the towbar lock. I removed the bolt (green arrow) and applied moderate force to try and extract the towbar assembly from the square receiver as Stan mentioned.
i took mine off this way..plenty of wd40 and bang with hammer.. ... - .- -.
T111RDY Member Since: 21 May 2012 Location: Dunbar Posts: 187 ![]() ![]() ![]() |
Me too - a big hammer! l:OolΞΞΞΞΞΞloO:l
I've read on here the WD40/Penetrating fluid and hammer technique works or,
Thanks all, looks like I need a bigger Sheffield screwdriver! |
Andy Member Since: 24 Feb 2009 Location: Shropshire Posts: 2951 ![]() ![]() ![]() |
Theres a blanking plug for the square hole when you remove the tow bar, so it looks nice and tidy 2010 MY Vogue SE TDV8 3.6 Stornoway Grey- fully loaded |
but the plug is bright red [mine was] ... - .- -.
T24RES Member Since: 22 Nov 2010 Location: Henley-on-Thames Posts: 936 ![]() ![]() |
This is the plug Stan
now that doesn't look to bad ian, mine was bright red and stood out like a sore thumb.. ... - .- -.
IIRC it was a fiver from the stealer. |
