![]() | Home > Technical (L322) > Re Range Rover Vogue 55 REG Starting problem |
There are a number of threads on here that have had similar issues. Sometimes it can be the barrel, sometimes the starter switch. Have a look with search and you should find them. Good luck. MY 2010 5.0 SC Galway green and sand interior!!
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8775 ![]() ![]() ![]() |
Diesel or petrol? There is nothing that can't be fixed with a hammer😜😜
Dolphinboy Member Since: 08 Dec 2009 Location: Bristol Posts: 3261 ![]() ![]() ![]() |
monkey, profile says 2005 TD6. (hover your cursor over his car image under his name and it should come up. |
comports Member Since: 20 Dec 2010 Location: Colchester Posts: 1763 ![]() ![]() ![]() |
If it turns over but does not start then it probably won't be the key or the barrel. If it was the key wouldn't turn or the engine would not turn over and try to fire I don't think.
Sorry on iphone cant do that....
TheAllSeeingPie Member Since: 18 Apr 2012 Location: Leeds Posts: 848 ![]() ![]() ![]() |
On iPhone / iPad you can tap the car icon under their username to see what they have. |
glenyboy26 Member Since: 17 Sep 2012 Location: hampshire Posts: 2 ![]() ![]() ![]() |
cheers for info so far
There are a number of code readers that can read the faults as the port is OBD II standard, depending on what equipment the garage has. But you don't necessarily have to go to the main dealers. Other option, is looking for members of FFRR close by with diagnostic equipment that can and want to help |
Samp Member Since: 20 Jul 2014 Location: Harare Posts: 1 ![]() |
Hi there. I have a similar problem with my 2003 range rover vogue. It's a diesel. Sometimes it starts and sometimes it plays up. Last week I had had it lifted on a low bed for 140km and when we got home after paying $400 to the recovery guys, guess what, it started!!! And yesterday it would not start.!! Checked it again after 4 hours, it started! By the way it has a new starter motor. What could be the problem guys? Help.. |
adigorn Member Since: 18 Mar 2010 Location: West Midlands/Birmingham Posts: 204 ![]() ![]() |
Fuel pressure related to me
Fuel pump, READ THE WIKI!!! do a search for it and have a read |
