Home > Technical (L322) > Kick Plates - How to remove
pld118
This should probably be in Maintenance section:
Can anyone please advise how to remove the metal factory fitted kick plates that butt up to the carpets (without breaking anything and so that it can be clipped back on)????
Post #183304 17th Apr 2013 6:57am
Jonno
United Kingdom 2012 Range Rover Autobiography 5.0 SC V8 Causeway Grey
Just lever them up with a large flat blade screwdriver. They're only clipped on. To replace line the clips back up and smack it back on. 5.0 supercharged autobiography
Gone-4.4 Vogue Lpg now unmapped
4.6 HSET Turbo Lpg mapped
Gone-Defender 90 200tdi
Gone - 3.9 Sprintex supercharged LPG
Gone - 3.9 Vogue LPG
Post #183306 17th Apr 2013 7:12am
pld118
Cheers
Post #183357 17th Apr 2013 2:02pm
TheAllSeeingPie
United Kingdom 2007 Range Rover Supercharged Supercharged Java Black
I'd recommend getting some of the clips before you have a go, they aren't usually expensive (usually 20-70p a clip depending on where it sits). That way you can wrench it off and just swap the clips over. I've found that putting new clips in the door cards and some of the pillars helped decrease squeaks and rattles massively.
07 Supercharged - Still breaking her in!
Boot soundproofing part 1 - http://www.fullfatrr.com/forum/topic15612.html
Custom exhaust - http://www.fullfatrr.com/forum/topic15296.html
18" wheels for Brembo equipped cars - http://www.fullfatrr.com/forum/topic15052.html
Post #183362 17th Apr 2013 2:55pm
verydisco
DO NOT use a screwdriver, this is not the tool for the job, get a PLASTIC trim removal tool or worst case senario, a kitchen flat blade thingy.
tool :
http://www.google.co.uk/search?q=plastic+t...mp;bih=896
Changing clips is a good idea, they are cheap enough, refitting is straight forward, just line up the 2 white plastic pins, easy. l=Oo\________/oO=l l:OolΞΞΞΞΞΞΞloO:l
Current
Previous:
Post #183363 17th Apr 2013 3:02pm
I am with verydisco on this. Use a spatula or palette knife from the kitchen Wink or from the workshop a flat wide paint scraper or putty knife. Slip it under the kick plate and gently prise up at one end. This way you won't break the clips!! .
Post #183426 17th Apr 2013 7:18pm
