Home > Technical (L322) > How do you adjust the tailgate lower door alignment?
Baron
United Kingdom 2011 Range Rover Vogue TDV8 Baltic Blue
My tailgate lower door has dropped slightly and I'd like to realign it as it's bugging me every time I look at the rear of my car. It's only 2 or 3 mm but enough to annoy when I can see the gap between the upper and lower doors is slightly bigger on the left than on the right.
Has anyone any experience of how to do this as I've had a look and can't see an obvious way to do it. Any info gratefully received. 4.4 TDV8 Vogue Baltic Blue MY11
Post #197040 30th Jun 2013 8:33pm
Post up some pics Baron so i can check its not somthing different...
Post #197041 30th Jun 2013 8:37pm
Baron
First pic is the right which is aligned okay.
Second pic is the left which has dropped slightly
And this pic provides a comparison though it's a little difficult to see.
Post #197048 30th Jun 2013 9:17pm
I believe you can adjust it up and down on the hinge bolts behind the carpeted cover...
Craig
Post #197062 30th Jun 2013 11:42pm
Baron
That's what I'm hoping but not clear which bolts to adjust, e.g is there an actual "adjusting bolt" or is it just a couple of bolts and a bracket/hinge? 4.4 TDV8 Vogue Baltic Blue MY11
Post #197064 1st Jul 2013 12:25am
I will look at one of ours in the morning and PM you sir Thumbs Up
Post #197067 1st Jul 2013 1:32am
Baron
Thanks Craig 4.4 TDV8 Vogue Baltic Blue MY11
Post #197074 1st Jul 2013 8:51am
TheAllSeeingPie
United Kingdom 2007 Range Rover Supercharged Supercharged Java Black
Can you post the answer on here please Craig as mines a bit wonky too.
07 Supercharged - Still breaking her in!
Boot soundproofing part 1 - http://www.fullfatrr.com/forum/topic15612.html
Custom exhaust - http://www.fullfatrr.com/forum/topic15296.html
18" wheels for Brembo equipped cars - http://www.fullfatrr.com/forum/topic15052.html
Post #197084 1st Jul 2013 12:58pm
