![]() | Home > Technical (L322) > Disappointed with Gap Diagnostics |
markcartlidge Member Since: 18 Mar 2013 Location: Nr Winslow, Buckinghamshire Posts: 120 ![]() ![]() ![]() |
They are normally very responsive. Must be a hiccup with there systems. |
Alistair Member Since: 11 Feb 2011 Location: Peterborough / Bordeaux / Andorra Posts: 8110 ![]() ![]() ![]() |
Agree - they are usually super responsive & helpful, so not sure what the issue is.
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35834 ![]() ![]() |
must be your computer thats the problem zulu man cos i can download the manual and if i can do that then i would probably be able to activate a iidtool as well..
Just had a tool around their site, including login and download, all seems fine. Suggest an email to Pat advising of the issues you are having. .
Weegie Member Since: 09 Jun 2014 Location: East Sussex Posts: 3271 ![]() ![]() ![]() |
Agree with the comments re Gap and website. Always had first class service.
supershuttle Member Since: 20 Mar 2011 Location: Lancashire Posts: 3950 ![]() ![]() ![]() |
I think site was a bit slow earlier maybe but I just connected and updated my tool (ooeer missis) |
dolph34 Member Since: 14 Sep 2015 Location: Kildare Posts: 1724 ![]() ![]() ![]() |
+1 for a top class service and response time. 2015 4.4 AB
Zulu 10 Member Since: 28 Nov 2014 Location: Hampshire Posts: 88 ![]() ![]() |
Thanks for all the responses. That's the reason why I quoted the fact that I was using Mx Tools, and I ran the test from two IPs before posting, so I know that it has nothing to do with my computer(s)... |
Rob99 Member Since: 03 May 2016 Location: Gatwick Posts: 1481 ![]() ![]() |
If you're very conversant with IT then you will know that internet connectivity can be flaky at times and for no apparent reason.
I first attempted to use the site at 06:00Z onwards and then later at 13:00Z, from two significantly geographically displaced IPs, which cannot be using the same infrastructure, so the problem was definitely not in the UK.
i think you're to clever for your own good, if we minions couldn't connect to the site we would just 'try later' ... - .- -.
Try connecting to fullfatrr.com @ 12:15 am GMT |
isnt that when the forum backs up on the servers... ... - .- -.
Blair Member Since: 03 Apr 2017 Location: Suffolk Posts: 72 ![]() ![]() ![]() |
Just got mine, and activated it no problem. Quite likely just a web-fart. Give it another go |
