![]() | Home > Technical (L322) > 3.6 TDV8 issues following split boost/intercooler hose |
MarianaWestminster Member Since: 14 Jun 2018 Location: UK Posts: 758 ![]() ![]() |
Oh and the issues have never gotten worse in 5 months and 6000 miles |
Grofus Member Since: 24 Mar 2017 Location: Co Clare Posts: 577 ![]() ![]() ![]() |
Well, you seem to have exhausted the enigine as a problem. Maybe, as suggested earlier, its a trans issue.
Andy Member Since: 24 Feb 2009 Location: Shropshire Posts: 2951 ![]() ![]() ![]() |
When you say reset adaptions, do you mean within the IID tool?
nino_nino Member Since: 29 Mar 2015 Location: pocitelj Posts: 690 ![]() ![]() ![]() |
Drive car in S mode for 3~4 days, it will help with D mode adaptacions. 2012 TDV8 Black Edition
I will give ZF a ring first thing Tuesday morning, see if they can point me in the direction of my closest ZF approved agent.
RR booked in to have the gearbox checked on Thursday. |
GraemeS Member Since: 07 Mar 2015 Location: Wagga area Posts: 2762 ![]() ![]() |
I suspect that the drop in fuel pressure is significant. Do you know where the pressure sensor is located - in the end of a rail or at the pump? |
I believe its in the end of the rail Graeme.
The fuel pressure sensor is indeed in the fuel rail.
The WSM for the 3.6 in the RRS states that pressure is adjusted depending on engine rpm and load so the lowered pressure but no DTCs that you noted is likely to be due to the reduced load rather than causing it. |
Ah i see so the reduced pressure/pressure drop is normal as the load on the engine reduces? |
But why did the engine load drop if you were still accelerating. 2007 Vogue TDV8 in Zermatt Silver with Charcoal |
This is what i was just wondering.
Clutch packs ???? I think the transmission check could be telling. Im intrigued. 2007 Vogue TDV8 in Zermatt Silver with Charcoal |
