![]() | Home > Technical (L322) > 3.6 TDV8 issues following split boost/intercooler hose |
MarianaWestminster Member Since: 14 Jun 2018 Location: UK Posts: 757 ![]() ![]() |
That would be really helpful and appreciated Cheezels.
Cheezels has very kindly sent me some data recorded from his own car (thanks again!) and from this I can see that his MAF sensors
Tugger Member Since: 28 Feb 2019 Location: Scotland Posts: 247 ![]() ![]() ![]() |
Have you swapped the MAF sensors round to see if the sensors is faulty, or if it is a correct reading? 09 RR Westminster 3.6TDV8 - Stornoway Grey / Black interior - now gone (sad face)
Grofus Member Since: 24 Mar 2017 Location: Co Clare Posts: 577 ![]() ![]() ![]() |
Faulty Maf or poor remap. Swsp them over and do another data run and see if the issue moves to the other bank. If not it has to be the re-map. 2007 Vogue TDV8 in Zermatt Silver with Charcoal |
Ive already tried swapping the MAF sensors over and the same bank still over reads. I have also tried substituting in a new MAF sensor but no difference.
I agree but what else is left.
cheezels Member Since: 23 Apr 2016 Location: Sunshine Coast Posts: 279 ![]() ![]() ![]() |
Is this the same MAF as the split hose and new turbo? 2007 3.6 TDV8 |
dolph34 Member Since: 14 Sep 2015 Location: Kildare Posts: 1724 ![]() ![]() ![]() |
Forgive me if you mentioned this in the previous pages but have you tried having the map returned to 'standard' by quantum? My local Quantum agent keeps the original map backed up. As its fitted by via obd port ( so handy enough to do )perhaps they would replace the old map so you can rule out the remap as a possible cause. 2015 4.4 AB
Same MAF as the split hose but not the new turbo that was the other bank (o/s) replaced by misdiagnosis. (Argh!)
I didn't realise they would charge to refit the old map. I would agree with it being a big coincidence but you seem to have covered most bases. Have you tried a different fault reader ? Again , feel free to ignore my post if these questions have been previously asked. 2015 4.4 AB
The really curious thing is how and why did removing and replaciing the offending top hose provide a temporary cure. Its just baffling. Is this a red herring?
That I cannot answer Grofus. |
I will do check for that but can fairly confidently say I get nothing like that.
Never got anything like that on my 3.6 |
