![]() | Home > Technical (L322) > 4.2 SC lean codes |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8776 ![]() ![]() ![]() |
So if the downstream ones can effect the fuel trims then a worn of faulty catalytic converter will effect the fuel trims..?? Maybe that's a reason for rich or lean codes..?? Or have I not understood that..?? They do like to make things complicated...!! Pete __________________________________________________ 2014 L405 Autobiography SDV8 4.4 Loire Blue Ebony interior-Click here for Thread- 2012 L322 Autobiography 5.0 Supercharged Ipanema Sand Sold 2011 L322 Vogue SE 4.4 TDV8 Baltic Blue. Sold 2002 L322 Vogue 4.4 V8 Epson Green (Fatty Offroader) Sold -Click here for Project Fatty off roader- |
mgrover Member Since: 03 May 2020 Location: Leeds Posts: 422 ![]() ![]() ![]() |
so bit more of an update. I kept getting misfire cylinder 1 when idling at 3k. I assume when sat in the driver's seat(UK) that its the left side of the engine?
Danwilderspin Member Since: 15 Jun 2016 Location: Cambridgeshire Posts: 2246 ![]() ![]() ![]() |
How are you getting on? Current stable:
waiting for cans of bg44k to turn up and a air sensor wrench so I can take mine off to take a look at them |
Air sensor? Just use long nose pliers if you don’t have the right bit. What about the o2s? Current stable:
i meant o2s sorry. but meh tool will be turned up in a day or do. itll just be me under the car with a jack so id rather make the job as easy as can be haha. learned that the hard way with the ace pipes |
What is this tool you speak of? I just drove it around for about 20 minutes to get the cats hot out it in full beige mode chucked under some axle stands and got under with a spanner and hammer and they cracked loose. Then went in for a cup of tea and waited for the cats to cool down and undid the rest by hand and swapped Current stable:
ah i was just gonna go with one of these
RR P38 Member Since: 12 Oct 2013 Location: Sydney Posts: 215 ![]() ![]() ![]() |
Agree with you waiting for the 02 spanner, they can be a real |
when i hold the revs at 3k rpm about 300 misfires if am understand the number correctly but only on cylinder 1. |
I didnt see anything like that number of missfires, but they were on #1 cylinder (3 missfires, so im discounting them)
So you had occasionally misfired only on one cylinder and you changed the downstream sensor and it went? Was it obvious the misfire and what number out of curiosity? Current stable:
On #1 cylinder
Ok fair enough - so is the ops problem sorted now? |
