Home > Technical (L322) > 4.2 SC lean codes
Page 5 of 12 <123 456 ... 101112>
mgrover
so bit of an update issues still not gone away but getting closer.
so on running just lpg for about 200ish miles. i only get lean codes for bank 1. so time to gives both cylinders the full treatment ie coils and plugs.
but when running petrol both cylinders have issues. so now I'll be dropping the tank soon i'll try and change fuel filter.
Post #556854 7th Jun 2020 9:14pm
RR P38
Australia 2003 Range Rover Vogue 4.4 V8 Java Black
You say cylinder 1, Im guessing you mean Bank 1 (pedantic, but keeping the peps informed)
Do you get a slight rough idle on a cold start up? feels like a little wobble from the drivers seat (before driving that is)
Looking at this more and retracing this thread Im leaning towards a bung coil or Spark Plug
On my other L322 with the GARBAGE M62 engine I was chasing a slight oil leak yesterday, crawling around under it I notice the post cat 02 sensor is unplugged completely and looks to have been this way a long time (no DTCs every recorded)
Post #556868 8th Jun 2020 2:43am
mgrover
Sorry yeah bank 1.I've edited it now.
Yeah slightly rough startup. When I removed a spark plug from cylinder 1 recently it looked lean with an orange tinge so I think it's time for a service. I might just do oil and the lot
Post #556869 8th Jun 2020 4:05am
RR P38
With super charged engines a cooler plug is installed so we dont burn holes in our piston crowns.
After you have changed plugs and the coil pack there is only one other thing to really do in that region and thats the injector, looking through your extensive list of replaced items its got to be getting frustrating by now.
Post #556870 8th Jun 2020 6:33am
Danwilderspin
You didn't mention but have you replaced the o2 sensors now I guess? did it make any difference? have you done the man with genuine too?
What I don't get is if I runs ok one one bank on gas not on petrol its not likely to be plugs is it? gs is more fussy about spark than petrol. It won't hurt to change them but I don't think it will be that. Same can be said for the coil, the leg is still using the same cold.
I think yous be better off doing the filter for the fuel and maybe an injector clean as it points to a fuel system issue as opposed to spark.... Just my 2 pence worth anyway Current stable:
2006 BMW M6
2007 4.2 V8 S/C FF
Gone:
2002 4.4 V8 FF
Post #556886 8th Jun 2020 9:50am
mgrover
nah nothing on the sensors/maf yet.
i wanna fix the bank 1 issue on lpg first, and then maybe bank 2 on petrol is an entirely separate issue. ie plugs are a bit Censored on bank 1 so it throws issues on about petrol/lpg and bank 2 has fuel injector problems.
Post #556890 8th Jun 2020 10:22am
Glibbs
Hi,
I don't know if this will help but I had similar issues with mine and I then decided to try premium fuel and then gave it an 'Italian tune up' and the issue has not returned. I've not returned to standard unleaded. Range Rover 4.2 SC
2 Range Rover Classics - one from new but both rusty now.
Rover 3.5 Coupe had since new.
Subaru Legacy 3.0.
BMW K1200RS.
Post #556906 8th Jun 2020 12:18pm
Danwilderspin
Also mGrover what if the o2 sensor is causing that bank permanent problems regardless of the fuel? If you have them just get on an change them it’s a 20 min job if you get it nice and warm and if you already have the maf 5min. You can rule them out the. And yea I agree plugs and coils next shout... but why not swap the plugs and coils from bank to bank and see if the lpg switches bank? If it doesn’t it’s not that and you can move onto something else or maybe the lpg just needs a tuneup after the heads being off! Current stable:
2006 BMW M6
2007 4.2 V8 S/C FF
Gone:
2002 4.4 V8 FF
Post #557001 8th Jun 2020 11:17pm
roverguy7
United States
Haylands wrote:
So if the downstream ones can effect the fuel trims then a worn of faulty catalytic converter will effect the fuel trims..?? Maybe that's a reason for rich or lean codes..?? Or have I not understood that..??
They do like to make things complicated...!!
That is correct, however with as well monitored as the cat is, you should get faults for it first, which will disable the sub-feedback fueling as well as several related fault codes from registering.
As to the situation at hand, if you are registering misfires, you will also be registering a lean condition(with the exception of valvetrain issues) as unused oxygen will be flowing through the exhaust.
An ignition misfire will result in that bank's O2 sensors reading lean, and downstream reading rich (until it sets a catalyst damaging misfire fault and cuts injection) as the unused oxygen is picked up by the upstream, and the unburnt fuel will react as in the cat, lowering the oxygen content exiting the cat.
How any of this is affected when running LPG, I have no idea. LPG conversions aren't as common in the states.
Post #557345 11th Jun 2020 6:05pm
mgrover
so i tried swapping cylinder 1 coil with cylinder 3 with no diff in terms of issues. since the fuel pump has been replaced i wanna get the fuel trims cleared. think ama honestly just bite the bullet and buy a gap tool and stop dicking about. that way I can reliably reset the trims.
i have a spare set of bosch plugs i may fit as well just to test. but I think first its time to clear the long term trims and confirm theres an actual problem.
Post #557379 11th Jun 2020 11:28pm
Danwilderspin
Iirc it needs ngk and why are you swapping into the same bank if you are trying to see if you misfire mows banks? Sure 1-2 and 2-1 would be better and swap the plugs over too? Current stable:
2006 BMW M6
2007 4.2 V8 S/C FF
Gone:
2002 4.4 V8 FF
Post #557385 12th Jun 2020 7:59am
mgrover
do you know the exactly part number? i dont wanna drop £80 on plugs that don't fit Razz am guessing NGK Iridium?
Post #557386 12th Jun 2020 8:26am
Danwilderspin
no but I'm pretty sure if you put your reg in the cp4l website it comes up with the correct ngk ones the more expensive ones. Current stable:
2006 BMW M6
2007 4.2 V8 S/C FF
Gone:
2002 4.4 V8 FF
Post #557406 12th Jun 2020 11:06am
mgrover
are they the iridium ones though? or just "better"
Post #557422 12th Jun 2020 12:54pm
lighthouse
United Kingdom 2011 Range Rover Autobiography 5.0 SC V8 Santorini Black
I had the same issue on my 4.2, went through all the same things you did, have you by any chance done a compression test?
Post #557424 12th Jun 2020 1:47pm
