Home > Maintenance & Mods (L322) > sidelight LEDs |
RichM63 Member Since: 10 Jul 2019 Location: Brittany Posts: 249 |
Toning down the side light lumens is easy enough.
29th Jun 2020 6:32pm |
AJGalaxy2012 Member Since: 11 Jun 2018 Location: Gainsborough Posts: 1446 |
The apparent resistance of LEDs will be much higher rather than lower then filament bulbs. The flashing is likely to be a 'cold filament check' Its a few short pulses of power and the current is measured to see if the bulb is present and working. The pulses are too short to illuminate a filament bulb but LED's are instant and on hence you see the flashes. I had this on my Touareg and I could switch off cold filament check to stop it with the diagnostics kit VCDS just like the IID tool for Range Rovers. BMW i3 Electric Car
29th Jun 2020 6:50pm |
fenlander Member Since: 14 Jan 2020 Location: Norfolk Posts: 124 |
Ah yes the cold filament test, I’ve wondered what that is in IIDControl, so will disable thanks.
29th Jun 2020 8:58pm |
pld118 Member Since: 25 Mar 2013 Location: Bairns Posts: 4218 |
Have you seen these threads: https://www.fullfatrr.com/forum/topic21661.html?highlight=led https://www.fullfatrr.com/forum/topic22712.html?highlight=work |
30th Jun 2020 6:33am |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 34870 |
ah the good old days Ryan ... - .- -.
30th Jun 2020 7:05am |
30th Jun 2020 12:53pm |
Doonhamer Member Since: 07 Jul 2017 Location: Thatcham, Berkshire Posts: 206 |
Just fitted these to my Fatty - Philips Light W5W T10, 6000 Kelvin - no can is error, nice and bright - will upload pic of packet if necessary L322 TDV8 4.4 - current
30th Jun 2020 7:25pm |
