![]() | Home > Technical (L322) > Electronic Handbrake Fault |
dhallworth Member Since: 10 Oct 2011 Location: Glasgow Posts: 3327 ![]() ![]() ![]() |
On mine there was no visible break in the cabling, it was more noticeable as a swelling in the cable under the insulation and when I touched it, it fell apart.
John w Member Since: 14 Jan 2018 Location: Cranleigh, Surrey Posts: 447 ![]() ![]() ![]() |
ok, roughly where ?
2 pictures showing from wheel arch, then closer to connector.
You can see the wiring loom on the right hand side of this picture coming through the body.
Ah ok, I didnt pull anything like that much out.
Take 2.
The car I had the fault on was a 2007 car which didn't have that sleeve around it.
OK, thanks for the reply.
Definitely worth trying the switch before going any further.
New switch arrived today. Swapped them over and it now works, Yay.
That's a great result, always nice when it's an easier fix!
davidrosenbloom Member Since: 02 May 2025 Location: USA Posts: 7 ![]() ![]() |
Could you be more specific to the wire location; I inadvertently touched my e brake and it fixed on; disconnecting battery let it loose; but I thought w/o looking however that it felt like the pull handle wasnt returning properly; ID just be happy to have it out of service so it doesnt happen again and so have pulled the two fiuses for it.
