Home > Technical (L405) > front knuckle cracking
Page 52 of 57 <123 ... 515253 ... 555657>
JamboM3
United Kingdom 2019 Range Rover Autobiography 2.0 PHEV Indus Silver
That’s positive!
Do you mean the unbroken one? Or analysis of the napped one
Post #720844 5th Jul 2025 12:10am
woodyrvf750
JLR have requested the broken one. They probably just want to check the serial numbers, who knows..
Post #720858 5th Jul 2025 8:28am
Mike Edwards
United Kingdom 2019 Range Rover Vogue SE SDV8 Mariana Black
I contacted my local dealer and asked about the recall for this.
They said my car had no recalls outstanding. It was first registered on 1 March 2013.
Does that mean it has had it done or is there a very specific range of VINs?
Post #721499 18th Jul 2025 12:06pm
DrF
United Kingdom 2013 Range Rover SVAutobiography 5.0 SC V8 Orkney Grey
I would be checking myself, as if it does fail, your dealer will absolve themself of any responsibility and you are then left with having to sort it out.
I wouldn't want to be relying on the fact your dealer said it was ok. Lots of examples of cars outside VIN range that have had issues, so unless your a very brave man, I would add it to your check list.
Better to be safe than sorry. Easy to check. Results if it does fail can be pretty scary.
That's just my thoughts.
DrF
Post #721501 18th Jul 2025 12:23pm
Mike Edwards
My thoughts exactly.
Post #721531 18th Jul 2025 6:44pm
Gremlin500
I’d just like to suggest new readers of this thread read the ENTIRE thread before posting.
There is much discussion about DIY testing kits etc.
I do mine every year.
I passed a BMW today with a similar “Horizontal Wheel” on a small roundabout in the town centre, so these issues are possibly not unique to our marque. V6 Vogue - “Less is More” - less to go wrong!
Post #721539 18th Jul 2025 8:26pm
Dave lincs
Hi I have a 2015 65 plate which has got the dreaded cracks but outside the recall I have contacted JLR and am taking it to Duckworth at market rasen on Monday for them to investigate the car
Post #721856 25th Jul 2025 1:05pm
woodyrvf750
Dave Lincs
PLEASE would you also record a serious safety defect with the DVSA to get more pressure on JLR to extend the recall range as cars like yours clearly have the same issue.
https://contact-dvsa.service.gov.uk/report-vehicle-safety-defect/
?si=SsbT3--iVBL2wbin
Post #721857 25th Jul 2025 1:44pm
Dave lincs
Done as requested, Has anyone been successful with getting this fixed if not in vin range
Post #721877 25th Jul 2025 4:43pm
Dave lincs
Post #721878 25th Jul 2025 4:43pm
4RRS
United Kingdom 2016 Range Rover SVAutobiography SDV8 Corris Grey
Got both sides on my 2016 outside of vin range replaced without any argument, even got a new o/s driveshaft when they destroyed it removing the knuckle.
On the flipside, other 2016 owners out of vin range have been given a flat no by JLR, not sure what the deciding factors are. L405 SV Autobiography LWB SDV8, finished in Aston Martin China Grey by ETO division.
Post #721880 25th Jul 2025 6:40pm
MadManxJim73
United Kingdom 2016 Range Rover Autobiography SDV8 Corris Grey
Would love to know what pressure can be applied to JLR - I've a 09/15 registered MY2016 and Duckworth have just confirmed its not subject to a recall for this - VIN ends GA253xxx - which I thought was within range.
Car is currently stranded at OFG Lincoln Ltd who are quoting just shy of £2200 to replace both sides (both are cracked).
Any suggestions = suspect I'll still have to pay upfront, but would love to be able to secure a recovery of my costs!
Post #722171 1st Aug 2025 9:42am
Dolphinboy
Dolphinboy wrote:
Ive just taken my Nov 2015 L405 into LR MD to have this looked at. They told me anything before 2016 is an automatic swap for new. 2016 onwards, they inspect and change if necessary.
Here is the letter they sent. my VIN is GAZ 654
Note the program number N759 (required by the dealer on application for inspection)
Post #722179 1st Aug 2025 3:18pm
woodyrvf750
My only recommendation would be to keep all the parts removed, log the incident with DVSA and keep hold of your invoice from OFG Lincoln with a view to claiming back the cost should the recall be extended!
Post #722396 6th Aug 2025 11:18am
mjdronfield
This just came up randomly in my FB feed. Someone with a 405 compared failed one to replacement and said new one is cast thicker….
 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #722432 6th Aug 2025 8:07pm
