Home > My Range Rover > L322 5.0 autobiography Sumatra Black - ownership journey
Page 1 of 8 12345678>
theJAFman
United Kingdom 2010 Range Rover Autobiography 5.0 SC V8 Baltic Blue
I am now in the market for a l322 5.0
This will be a replacement to my 4.6is x5
Having seen 6 cars at all ends of the market they all need alot of love mileage means nothing condition is everything.
Edit
I almost bought a 2 owner car with many works planned but ended up with different car as per below.
Post #722765 12th Aug 2025 11:01pm
Gsxr1250dave
Glad you found one at last. I did my own sc refurb on my 4.2 or my mate did use a genuin coupler not the solid type had to redo mine as the solid types rattles badly. Thumbs Up
Post #722766 13th Aug 2025 6:20am
theJAFman
Thanks just going to send the unit off for a full rebuild i cant be bothered to do all this later
Is there a parts look up catalogue like realoem for bmws so i can buy it all from autodoc with oem brands
Post #722786 13th Aug 2025 11:46am
JCW
https://lrcat.com/#!/12719/104532/106300/8448/106888
I’m planning on doing the zip-tie tensioner & guides replacement on my 5.0 SC so would be good to compare notes on this in due course Thumbs Up
My research suggests this is the main set of tools needed to remove / replace the crank pulley-
https://www.ebay.co.uk/itm/316908189755
I have this in my eBay watchlist and the seller sent me an offer to buy at £80.
The only other special tool I think is needed is a crankshaft timing tool, inserted in place of the crankshaft position sensor & is primarily to ensure everything is aligned. Circled in this kit (which is the full kit needed if you’re doing the full chain replacement)
I’m also about to replace the SC coupler (with a genuine coupler, not solid) and will decide on whether to replace the snout once it’s apart and I can assess the bearing and coupler drive condition.
The zip-tie tensioner replacement method and snout replacement were both official LR tech bulletins which I can send to you if you don’t already have them.
Sounds like we’re on a similar path! Jonathan
2010 L322 5.0 SC Autobiography Black
2007 Defender 90 XS Hardtop
Post #722789 13th Aug 2025 12:59pm
theJAFman
Thank you for the in depth reponse JCW
Only a crank lock tool is needed from what i gather now, ill try get it for 80 also.
Ill sell it on here once im done along with the bumpers and wheels.
What mileage is your car? Mines at 120k having spoken to powerhouse they claimed every single supercharger needs a full rebuild at 800 posted and they only last 150k.....what bs
So i will just do the snout, coupler and oil and call it day.
I went to see a 80k car that was up for 15 i offered him 9.5 at the time as it was quite rusty had some scartches and no ac he told me no. 2 weeks later hes asking me he accepts my offer....
Sadly for the sellers there are very few stupid people like us who buy 15 year old 5 litre headaces 😄 and they dont realise its a buyers market! Just like houses.
Post #722813 13th Aug 2025 9:28pm
JCW
This is mine -
https://www.fullfatrr.com/forum/topic73777.html
I managed to get it for £5,750 which I was pretty happy with given the work needed and that it’s a slightly rarer Autobiography Black model. The downside is it has 143k miles, although I do very few miles so it won’t increase by much while I have it.
I’ve already ticked most of the jobs off the list, the main ones left to do are the SC coupler which definitely needs changing having checked the nose pulley free play / run the engine with the belt off and then the tensioners / guides on a preventative basis. There are no current or historical codes for timing issues, albeit nothing in the history suggesting they’ve ever been changed, so likely still has the earlier parts fitted. Then it’s just routine maintenance stuff.
Not sure how long I’ll keep it as I bought it as a project to tinker with Very Happy Jonathan
Post #722817 14th Aug 2025 5:56am
theJAFman
Thank u jcw i have seperate tinker car its quite different
Full order list am i being ott with the idlers and belt tensioners?
Edit removed boring parts list not relevant to purchased car anymore
Post #722827 14th Aug 2025 10:00am
JCW
That’ll keep you busy for a while!
Ref the belt pulleys and tensioners, whilst you’re in there it makes sense to change them in my view.
However, rather than buying all new parts, you can just replace the bearings, they are all the same size.
SKF 6203-2RSH
https://bearing-king.co.uk/products/6203-2...-12mm-wide
Obviously means pressing out the old and installing the new but at a fraction of the cost. Jonathan
Post #722831 14th Aug 2025 11:24am
theJAFman
Wow you are the man in the know!
I can press it with some sockets and my vice
How many to get then just 2 right
Post #722835 14th Aug 2025 12:00pm
JCW
Very Happy I can’t take all the credit, I followed in the footsteps of fellow forum member Dhallworth.
I think you’ll need 4 or perhaps 5 bearings - two (or perhaps three?) idlers and two tensioners. Jonathan
Post #722840 14th Aug 2025 1:27pm
theJAFman
Edit
Post #722905 15th Aug 2025 1:25pm
theJAFman
Finally got one
4 owners from new 61 plate 5.0 sc autobiography
Driver super smooth no rattles or knocks and super strong on power
128k miles full service history last service including plugs 125k
Sumatra black
fully black interior
Chauffer controls
Hk
Auto deploy steps
And the usual stuff
Chains water pump and beltdrive done at 121k this is the smoothest engine i heard even compared to a 80k version
2 air shocks changed recently
High pressure fuel pump changed in 2018
Gearbox and driveline oils done at 110k
Issues of the bat
Battery very weak easy fix full charge and repair cycle to start
Oil leak around oil filter housing
Small Coolant leak
Parking Sensors button flashes no beeps
Flicker tastic cheap lights all round sadly
Interior lights middle mains don't come on when pressed or when door opens fuse?
Fog lights dont work fuse?
Needs new front discs and pads
Rears
Time to adress the above hopefully all is fairly simple
Then make it look classy over the comming week
it fits in my cave! Comfortably
Post #723027 17th Aug 2025 11:45pm
kevinp
You know everyone now hates you for having such a big cave!! Rolling with laughter
Post #723035 18th Aug 2025 11:24am
theJAFman
Hopefully not !
Post #723040 18th Aug 2025 1:07pm
theJAFman
Coolant leak is below supercharger
So i found the coolant leak sadly supercharger off job
I was also missing a 36m fan clutch spanner hindering further progress to track oil leak
Battery is toast cant hold charge what so ever
Car has some silly audio install with switched power to amp and capacitor as well as stick on tweeters on dash.
Need to rip all this crap out
Im guessing i need that common hose near the rear side?
At this point best replacing
Check snout
valley pan gasket
Charger gasket
Manifold gasket
Coolant pipes
Cooler?
Any other suggestions ?
Car also needs 2 rear shocks 1 is leaking
Disc and pads all round a full fluid service and that should be all the mechanical stuff for now
Before looking to parking sensors and lighting issues
On the bright side wheels came!
Edit
Jacking this car up really suck especially with deployable side steps what a ball ache!
There is no rear centre jacking point and the subframe is blocked by exhaust pipes
Im going to try find the front one today to asses the rest of the under carrige so far looks ok and not too rusty at all
Post #723057 18th Aug 2025 7:46pm
