![]() | Home > Maintenance & Mods (L322) > Wiper "thud' on direction change |
supershuttle Member Since: 20 Mar 2011 Location: Lancashire Posts: 3926 ![]() ![]() ![]() |
Guys,
Plenty of them do this, in fact probably all would if the wipers weren't changed regularly. The worst case is where it gets so bad that it scratches the screen at the direction change point.
EDIT. There is a TSB about this somewhere. 86 degrees is mentioned from memory. Quite how you measure that is beyond me but I have also played with this adjustment. It makes a small difference on a new blade and is worth doing. |
there she blows................. |
Do the covers of the bolts just pull off? Geoff |
Sure do. |
simon1233 Member Since: 13 Jun 2011 Location: Leyland, sometimes Darmstadt Posts: 650 ![]() ![]() |
Yup, one of the few times in life that brute force and ignorance are your friends |
Thanks guys I'll get onto it tomorrow, it's actually a Right Royal PITA (RRPITA |
Geoff, if you feel round the 'arm' section of the cover you can feel that it overlaps the arm underneath, just pull this out sideways a little and the cover will lift off |
carlos50 Member Since: 03 Feb 2011 Location: North England Posts: 717 ![]() ![]() ![]() |
I have a similar issue in that my passenger wiper is starting to scuff the glass at its max wipe point. Its slowly getting worse but doesn't make any thud noise, it does smear when wiping?
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16369 ![]() ![]() ![]() |
When removing the wiper arms, if you undo the nut then making sure the nut is wound down the thread enough to be flush with the top of the spindle. Then take some plummers adjustable pliers (the bigger the better) and put the jaws on the top of the nut and under the bottom of the wiper arm and squeeze together... The arm should pop off, the nut both stops the arm from flying off and protects the threaded end of the spindle from damage with the plummers pliers...
Craig, have you got yours set as per the dimensions on here?
So I spent all morning fiddling with the angle of the dangle - slight differences still thud.
So the slight adjustments make no difference?
enter 'range rover bosch 808' in the ebay search.. ... - .- -.
