![]() | Home > Technical (L322) > Range Rover Key Transponder |
andrew.aa Member Since: 16 Aug 2011 Location: PERUGIA Posts: 102 ![]() ![]() ![]() |
someone knows the exact type of transponder inside the key? should be type PCF7936AS but I'm not sure because all my keys are lost. Anyone has the key for quick check? I need generate new key and transponder, I'm tolking about L322 BMW with 3 buttons key, no flip key.
you want the phillips 44 chip
thank you Daveo, I Can't open your link due the Europol block. anyway I know that is Chip nemed ID44 but the correct code of Phlips Id 44 wich is? Sometime called PCF7935AS and sometime PCF7936AS
so you are confirm that the correct chip is PCF7935AS'Right?
I see that original key can supply with PCF7936 transponder as follow link:
I would like to thank those who answer my question and who has kindly checked his key.
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6425 ![]() ![]() |
What just happened here?
yes there are several chip types but i am not sure what comes with what, fit PCF7936AS my key comes up as a 57 block key rover and can only be read by land rover, they would order the chip and it would be part programmed, they then would then complete the program in the car, V8 facelift Range Rover Autobiography 22" wheels.
just looked at my other key and thats a PCF7935AS chip...4.4 petrol V8 facelift Range Rover Autobiography 22" wheels.
joe,yes, I bought a new blank key, with transponder, and had PCF7936AS inside, then I bought others 5 transponders type PCF7935AS because BMW editor can not write PCF7936AS (only PCF7930AS PCF7935AS E) there isn't a tool, that can read EWS and Generate PCF7936AS directly
So I believe that the PCF7936AS be used on newest models |
what programmer did you use. V8 facelift Range Rover Autobiography 22" wheels.
I bought EWS EDITOR, which encodes ALL BMW ews ecu , can read and program blank transponder. works with all ews but only with two types of transponders. (PCF7930AS - PCF7935AS) |
i have been told that my chip can not cloned, it has to be ordered part programmed and then the dealers complete the process, if you had lost both your keys haw did you get you file to programmed the new chip.. V8 facelift Range Rover Autobiography 22" wheels.
