Home > Technical (L322) > Range Rover Key Transponder
andrew.aa
Italy 2004 Range Rover Westminster 4.4 V8 Java Black
someone knows the exact type of transponder inside the key? should be type PCF7936AS but I'm not sure because all my keys are lost. Anyone has the key for quick check? I need generate new key and transponder, I'm tolking about L322 BMW with 3 buttons key, no flip key.
I am very grateful if someone could check
Post #128973 2nd Jul 2012 5:01pm
daveo
you want the phillips 44 chip
http://www.autokeys.us/product_details.php...tem_id=753 V8 facelift Range Rover Autobiography 22" wheels.
Post #129032 2nd Jul 2012 8:38pm
andrew.aa
thank you Daveo, I Can't open your link due the Europol block. anyway I know that is Chip nemed ID44 but the correct code of Phlips Id 44 wich is? Sometime called PCF7935AS and sometime PCF7936AS
, so is very difficult understand for me. Iwish someone can chek this transponder by the key
this ID44 Transponder is PCF7935 AS Follow link:
http://wiisingonline.com/Philips-PCF7935AS...3-319.html
http://www.uobd2.com/wholesale/bmw-id-44-t...-1725.html
http://www.obd2motor.com/bmw-id-44-transponder-chip_p4839.html
The problem is that I have no other transponder key to chek this,
I removed also EWS 3 from the car and read immo by the EWS EDITOR BMW , than generate new chip PCF7935AS.
The new transponder can unlock steering and igniction barrel, but engine can't start.
For this reason I thinking that mybe need PCF7936AS chip, different from pcf7935as
Post #129059 2nd Jul 2012 9:53pm
daveo
i think when prog a chip it has to be with the car as the prog talks to the cars ecu and copy's the current rolling code
that link i sent you shows the phillips chip and that does work as i have had it programmed. V8 facelift Range Rover Autobiography 22" wheels.
Post #129066 2nd Jul 2012 10:30pm
andrew.aa
so you are confirm that the correct chip is PCF7935AS'Right?
And most important , you had performed new key chip? but i'M not understand because I bought 2 new flip style keys like this Bow down
http://www.autokeytransponder.com/Product_details.php?id=2253
the keys arrived with ID44 chip inside (pcf7936as) than are uncorrect or what?
Bmw EWS editor can write only PCF7935 and PCF7930,
At this point I believe that correct chip is PCF7936 ?? Rolling Eyes
I don't know what think about
Sorry Daveo , but I need restore the variable part of the code EWS agreed with the engine control unit DME / DDE ?
I tried also to do EWS-DME Allignment but with inpa edibas and BMW Scaner and GT1 is impossible
Post #129078 2nd Jul 2012 11:06pm
andrew.aa
I see that original key can supply with PCF7936 transponder as follow link:
http://www.keyecu.com/goods.php?id=2873
Can anyone confirm?
Post #129288 4th Jul 2012 12:02am
andrew.aa
I would like to thank those who answer my question and who has kindly checked his key.
anyway, after much research, I discovered that, from 2002 to 2006, were mounted different transponders
i.e. 56 plate have PCF7936AS inside, whle 52 plate diesel fit PCF7930AS,
would be nice to know, what years and what transponder.
as I told allmy keys was lost, so I generated new transonder with PCF7935AS, and work correctly.
if anyone is interested, or want to take your key, it would be nice
Post #130711 12th Jul 2012 2:51pm
What just happened here?
Can you simply buy the key with the transponder, and then code it to the car, without outside/dealer intervention? Or did I miss something? .
Post #130713 12th Jul 2012 3:37pm
daveo
yes there are several chip types but i am not sure what comes with what, fit PCF7936AS my key comes up as a 57 block key rover and can only be read by land rover, they would order the chip and it would be part programmed, they then would then complete the program in the car, V8 facelift Range Rover Autobiography 22" wheels.
Post #130753 12th Jul 2012 6:52pm
daveo
just looked at my other key and thats a PCF7935AS chip...4.4 petrol V8 facelift Range Rover Autobiography 22" wheels.
Post #130762 12th Jul 2012 7:35pm
andrew.aa
joe,yes, I bought a new blank key, with transponder, and had PCF7936AS inside, then I bought others 5 transponders type PCF7935AS because BMW editor can not write PCF7936AS (only PCF7930AS PCF7935AS E) there isn't a tool, that can read EWS and Generate PCF7936AS directly
Now my generated, PCF7935AS works properly on my V8 4.4, but I do not know what is the original.
My friend, has a 2002 diesel and has key with PCF7930AS
Furthermore, 5 days ago I bought a used key on t ebaya, from a 2006 diesel, inside I found PCF7936AS
Post #130886 13th Jul 2012 1:33pm
andrew.aa
So I believe that the PCF7936AS be used on newest models
Post #130887 13th Jul 2012 1:33pm
daveo
what programmer did you use. V8 facelift Range Rover Autobiography 22" wheels.
Post #131300 16th Jul 2012 1:01am
andrew.aa
I bought EWS EDITOR, which encodes ALL BMW ews ecu , can read and program blank transponder. works with all ews but only with two types of transponders. (PCF7930AS - PCF7935AS) Big Cry . the editor is very easy and intuitive,
with this tool , you can clone transponder or generate new blank chip.
if someone needs generate transponder key or encode ews, I can share it, but it is not easy from here Big Cry Big Cry .
I bought also IMMO emulator, but need ISN number to fit it, and the number can't be read by INPA,BMW SACANNER or GT1 and/or SSS Progman, that I usually use as diagnostic tool.
Post #131353 16th Jul 2012 12:49pm
daveo
i have been told that my chip can not cloned, it has to be ordered part programmed and then the dealers complete the process, if you had lost both your keys haw did you get you file to programmed the new chip.. V8 facelift Range Rover Autobiography 22" wheels.
Post #131420 16th Jul 2012 4:13pm
