|  | Home > Technical (L322) > Range Rover Key Transponder |
| andrew.aa Member Since: 16 Aug 2011 Location: PERUGIA Posts: 102      |
 someone knows the exact type of transponder inside the key? should be type PCF7936AS but I'm not sure because all my keys are lost. Anyone has the key for quick check? I need generate new key and transponder, I'm tolking about L322 BMW with 3 buttons key, no flip key.
|  2nd Jul 2012 4:01pm |
| daveo Member Since: 21 Oct 2009 Location: london Posts: 2307      | you want the phillips 44 chip
|  2nd Jul 2012 7:38pm |
| andrew.aa Member Since: 16 Aug 2011 Location: PERUGIA Posts: 102      | thank you Daveo, I Can't open your link due the Europol block. anyway I know that is Chip nemed ID44 but the correct code of Phlips Id 44 wich is? Sometime called PCF7935AS and sometime PCF7936AS
|  2nd Jul 2012 8:53pm |
| andrew.aa Member Since: 16 Aug 2011 Location: PERUGIA Posts: 102      | so you are confirm that the correct chip is PCF7935AS'Right?
|  2nd Jul 2012 10:06pm |
| andrew.aa Member Since: 16 Aug 2011 Location: PERUGIA Posts: 102      | I see that original key can supply with PCF7936 transponder as follow link:
|  3rd Jul 2012 11:02pm |
| andrew.aa Member Since: 16 Aug 2011 Location: PERUGIA Posts: 102      | I would like to thank those who answer my question and who has kindly checked his key.
|  12th Jul 2012 1:51pm |
| Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6434    | What just happened here?
|  12th Jul 2012 2:37pm |
| daveo Member Since: 21 Oct 2009 Location: london Posts: 2307      | yes there are several chip types but i am not sure what comes with what, fit PCF7936AS my key comes up as a 57 block key rover and can only be read by land rover, they would order the chip and it would be part programmed, they then would then complete the program in the car, V8 facelift Range Rover Autobiography 22" wheels.
|  12th Jul 2012 5:52pm |
| daveo Member Since: 21 Oct 2009 Location: london Posts: 2307      | just looked at my other key and thats a PCF7935AS chip...4.4 petrol V8 facelift Range Rover Autobiography 22" wheels.
|  12th Jul 2012 6:35pm |
| andrew.aa Member Since: 16 Aug 2011 Location: PERUGIA Posts: 102      | joe,yes, I bought a new blank key, with transponder, and had PCF7936AS inside, then I bought others 5 transponders type PCF7935AS because BMW editor can not write PCF7936AS (only PCF7930AS PCF7935AS E) there isn't a tool, that can read EWS and Generate PCF7936AS directly
|  13th Jul 2012 12:33pm |
| andrew.aa Member Since: 16 Aug 2011 Location: PERUGIA Posts: 102      | So I believe that the PCF7936AS be used on newest models | ||
| daveo Member Since: 21 Oct 2009 Location: london Posts: 2307      | what programmer did you use. V8 facelift Range Rover Autobiography 22" wheels.
|  16th Jul 2012 12:01am |
| andrew.aa Member Since: 16 Aug 2011 Location: PERUGIA Posts: 102      | I bought EWS EDITOR, which encodes  ALL BMW ews ecu , can  read and program blank transponder. works with all ews but only with two types of transponders. (PCF7930AS - PCF7935AS)  | ||
|  16th Jul 2012 11:49am |
| daveo Member Since: 21 Oct 2009 Location: london Posts: 2307      | i have been told that my chip can not cloned, it has to be ordered part programmed and then the dealers complete the process, if you had lost both your keys haw did you get you file to programmed the new chip.. V8 facelift Range Rover Autobiography 22" wheels.
|  16th Jul 2012 3:13pm |
| Posting Rules
 . the editor is very easy and intuitive,
