![]() | Home > My Range Rover > How to modernise a 2003 Vogue V8 |
rich89 Member Since: 05 May 2013 Location: United Kingdom Posts: 295 ![]() ![]() ![]() |
Thanks.
Bushy513 Member Since: 25 Feb 2013 Location: Colchester Posts: 392 ![]() ![]() ![]() |
On the computer screen roll the selector over to the trip you want to reset then push in the button and select reset Bushy
Budgie Member Since: 09 Jul 2012 Location: Stornoway Posts: 267 ![]() ![]() |
First off I would get it serviced, if not already done, and have the gearbox oil & filter changed if it's not recorded in the service record.
TheAllSeeingPie Member Since: 18 Apr 2012 Location: Leeds Posts: 848 ![]() ![]() ![]() |
IID can clear all faults, |
I believe you can get rid of the air suspension inactive fault code, as long as there isn't a genuine fault, by simply turning the steering wheel from lock to lock to reset the sensors. You tube it, powerful uk posted a video about this. Bushy
Rich86 Member Since: 10 Mar 2013 Location: Surrey Posts: 509 ![]() ![]() ![]() |
Morning guys,
markcartlidge Member Since: 18 Mar 2013 Location: Nr Winslow, Buckinghamshire Posts: 120 ![]() ![]() ![]() |
My IID Tool arrived yesterday. Great piece of kit but if you have dodgy pixels it may be hard work. I made some config changes, turned off steering wheel retraction, turned on auto lock function. Cleared all faults and will see which have returned today.
This will tell you what it can do for your year of FF: http://www.gap-diagnostic.com/products/iidtool.html
A1GSS Member Since: 24 Dec 2010 Location: Saffron Walden, Essex Posts: 1973 ![]() ![]() |
It says that full fuNctionality on all systems wil be available by autumn 2013.
No, you can plug the IID Tool into a USB port on your PC and update the software that way. So you'll still get the latest updates but have the pleasure of using it in the meantime. |
Well the one thing I really need to be able to do is clear the EASN fault.
Yes, for sure it will do that. Lots of EAS functionality included. I can email you a copy of the manual if you like. Graham
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16369 ![]() ![]() ![]() |
It will certainly tell you what the fault is so you can repair it... |
