Home > Technical (L322) > Transfer box motor? |
RRPhil Member Since: 22 Aug 2011 Location: Blackburn, Lancashire Posts: 912 |
The Range Rover never suffered from the ‘split drum’ issue as, by 2002, ZF were fitting the stiffened A-clutch drum to all 5HP24s
2nd Nov 2014 4:12pm |
tymh Member Since: 21 Apr 2014 Location: Garstang Posts: 299 |
Thanks for that - at least it puts my mind at rest with regard to the fail safe issue! Tym
2nd Nov 2014 6:37pm |
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6399 |
Browsing through RAVE this evening (as you do!) I noticed a section for replacing the "fuse" for the Transfer Box, which is located in the engine compartment below the Transfer Box ECU. From the circuit diagram this is a 50 amp jobby. Could this have anything to do with it not switching from low to high ?
5th Nov 2014 1:12am |
Thanks Joe - now it's in high range I'm loathed to try this as I don't want it stuck in low again!
17th Nov 2014 8:25am |
povh Member Since: 16 Oct 2015 Location: Ljubljana Posts: 4 |
Sorry for link to another forum I was just just too lazy...
22nd Feb 2016 10:50am |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 34933 |
rather than linking to another forum , can you post your solution here... ... - .- -.
22nd Feb 2016 11:05am |
Meerbusch Member Since: 16 May 2012 Location: Zürich (CH) + Düsseldorf (D) Posts: 285 |
sorry, had posted the link, my english was not able to read the rules.... , but the Information in this link is old and well known...., it is to clean the poti. TDV8 4.4 from 2012, 278.000km like new + Lancia Flavia Coupe 1964 + RRS L494 3.0 SDV6 + C220CDI Convertible 2021 |
22nd Feb 2016 11:22pm |
It is not enough to clean the potentiometer as it is not really dirty. You have to modify sliding pins in the potentiometer. If you look the picture you will see where is a problem ( and sollution ) |
23rd Feb 2016 2:53pm |
Jimmy C Member Since: 05 Feb 2015 Location: midlands Posts: 115 |
not being mechanically minded can you arrow the 5 sliders on the picture that need bending as looking at the picture i have no idea. |
24th Feb 2016 9:54am |
On this pictuere you can see sliders,
24th Feb 2016 2:37pm |
Thanks, not sure if im willing to try as can be a little heavy handed dont want to break anything!
25th Feb 2016 3:32pm |
mr_spock Member Since: 07 Apr 2016 Location: Welwyn, Hertfordshire Posts: 311 |
I suspect I may have this problem. Has anyone tried something like this to repair the track:
28th Apr 2016 10:16am |
verydisco Member Since: 10 Dec 2009 Location: UK/US Posts: 2952 |
Hi Gang,
11th Jun 2016 2:44pm |
That's what I did in the end. |
11th Jun 2016 5:41pm |
