Home > Technical (L322) > Transfer box motor?
Page 4 of 7 <1234567>
RRPhil
The Range Rover never suffered from the ‘split drum’ issue as, by 2002, ZF were fitting the stiffened A-clutch drum to all 5HP24s
Phil
Post #290287 2nd Nov 2014 3:12pm
tymh
United Kingdom 2008 Range Rover Vogue TDV8 Tonga Green
Thanks for that - at least it puts my mind at rest with regard to the fail safe issue! Smile Tym
(current) L322 3.6 TDV8 Vogue 2008 Tonga Green
(previous) L322 4.4 LPG Vogue SE 2003
If it sticks, force it. If it breaks, it needs replacing anyway.
Post #290313 2nd Nov 2014 5:37pm
Mistercorn
United Kingdom 2010 Range Rover Autobiography 4.4 V8 Java Black
Mine failed, I took the motor off, removed the potentiometer, took the cover off, gave it a good cleaning with some IPA and switch clearer and then put it all back together. A pretty easy job to do, you don't even have to jack the car up to do it. Certainly worth a go before spending any money on it.
MC
Post #290404 3rd Nov 2014 8:39am
Browsing through RAVE this evening (as you do!) I noticed a section for replacing the "fuse" for the Transfer Box, which is located in the engine compartment below the Transfer Box ECU. From the circuit diagram this is a 50 amp jobby. Could this have anything to do with it not switching from low to high ?
(Shot in the dark as guessing if it is happy to move from high to low, the power must be there?) .
Post #290799 5th Nov 2014 12:12am
tymh
Thanks Joe - now it's in high range I'm loathed to try this as I don't want it stuck in low again!
I'm intrigued by the suggestion to clean the potentiometer with Indian Pale Ale... Tym
Post #293667 17th Nov 2014 7:25am
povh
Slovenia 2005 Range Rover Autobiography Td6 Giverny Green
Sorry for link to another forum Smile I was just just too lazy...
So here we go with proper post:
Today I opened potentiometer and found the source of the problem. There are holes in the graphite layer, right under the sliders of the potentiometer. Holes are in the High range position, where transfer box is most of the time. Beside that it moves just a bit every time engine starts, so sliders just rub against graphite surface and "eat" it.
This problem was not detected either with ohm-meter or oscilloscope.
So I just bent all five sliders for about 1mm so they are running on fresh track of the graphite and sensor should be OK for another 10 years.
Price : 0
Time: 1h
It is working for me for some time now.[/img]
Post #373520 22nd Feb 2016 9:50am
rather than linking to another forum , can you post your solution here... ... - .- -.
Post #373521 22nd Feb 2016 10:05am
Meerbusch
Germany 2017 Range Rover Vogue SDV8 Carpathian Grey
sorry, had posted the link, my english was not able to read the rules.... Wink, but the Information in this link is old and well known...., it is to clean the poti. L405 SDV8 2017 + Lancia Flavia Coupe 1964 + L322 TDV8 2011 + RRS L494 3.0 SDV6 + C220CDI Convertible 2021
Post #373656 22nd Feb 2016 10:22pm
povh
It is not enough to clean the potentiometer as it is not really dirty. You have to modify sliding pins in the potentiometer. If you look the picture you will see where is a problem ( and sollution Smile )
Post #373707 23rd Feb 2016 1:53pm
Jimmy C
United Kingdom 2003 Range Rover Vogue Td6 Zambezi Silver
not being mechanically minded can you arrow the 5 sliders on the picture that need bending as looking at the picture i have no idea.
Post #373838 24th Feb 2016 8:54am
povh
On this pictuere you can see sliders,
They are running on graphite track and you can see holes where sliders lay most of the time. Sliders are not on the pic so I painted them with red color:
I bent sliders like marked with green:
If you want to open potentiometer you have to cut glued part with sharp knife and slowly open cover with flat screwdriver.
Bending slider pins is very precise work so you can destroy them in a second, so be careful!
Hope it is more clear now Smile
Post #373911 24th Feb 2016 1:37pm
Jimmy C
Thanks, not sure if im willing to try as can be a little heavy handed Embarassed dont want to break anything!
You should try and get a few, repair and sell I would be willing to try one Mr. Green
Post #374105 25th Feb 2016 2:32pm
mr_spock
I suspect I may have this problem. Has anyone tried something like this to repair the track:
http://uk.rs-online.com/web/p/conductive-adhesives/3888673/
If anyone has a broken motor/potentiometer they don't need I'll happily give it a try and document for the forum.
Ian
Post #384248 28th Apr 2016 9:16am
verydisco
Hi Gang,
Same problem so I used Povh's technique (slightly bended the connectors outwards) and it all works fine now.
It took 2 to 3 hours all in, but well worth it considering the price of the whole replacement unit.
Note that I only took the motor's outer plate off (6 screws) and then the potentiometer itself (one circlip off then unplug it).
The longest part it to open and close it properly (I used a dremel and a soldering iron)
All fitted back and work 100% (for now...)
Cheers for sharing this great trick Povh! l=Oo\________/oO=l l:OolΞΞΞΞΞΞΞloO:l
Current
Previous:
Post #391236 11th Jun 2016 1:44pm
mr_spock
That's what I did in the end.
Post #391264 11th Jun 2016 4:41pm
