Home > Maintenance & Mods (L322) > Retro fitting Paddle Shift to early L322
Page 13 of 14 <123 ... 121314>
mattstevenson2005
United Kingdom 2003 Range Rover Autobiography 4.4 V8 Java Black
Hi Jord
It can't really be done hardwired while keeping the heated wheel. The slip ring only has a limited number of tracks and they are all in use if you have the heated wheel. I came up with the wireless solution as a work around for this limitation, I have been using it for the past 5/6 years without any issues, not even had to change the batteries in the transmitter yet!
Matt Current
2012 Range Rover 5.0L SC Ultimate Edition
2012 Range Rover 4.4L TDV8 Autobiography
2010 Range Rover 3.6L TDV8 Autobiography
2003 Range Rover 4.4L V8 Bespoke Vehicle
Inventor of the retro fit paddle shift and many other modifications.
Creator of the custom 2010+ RR MK4 splash screen.
Creator of the Range Rover CarPC and lots more!
Founder of Range Rover Owner
rangeroverowner.com | Facebook.com/RangeRoverOwner | Latest Videos ➞ YouTube.com/RangeRoverOwner
Post #398253 29th Jul 2016 2:12pm
JPHC
United Kingdom 2007 Range Rover Supercharged 4.2 SC V8 Java Black
Thanks for the reply mate. Hmm might have to do that then...
I just re-read the thread and there was talk of using the same 12v for the steering wheel controls and the heated wheel, thus freeing those existing wires and tracks. Because the wheel and the control have their own independent power sources, you could essentially stick them both on one 12v. 10amp fuse was enough for the wheel and buttons but you could add an extra inline regardless....
Ok you loose the wheel controls if the wheel blows its fuse, but how often does that really happen....
Just think this is a much cleaner install Jordan
'56 SC 4.2 ‘21-Current
'56 SC 4.2 ‘16-‘18
Post #398259 29th Jul 2016 2:29pm
mattstevenson2005
You would need an extra 2 tracks on the slip ring as the heating element has 12+ Gnd and data, and the paddle shift system needs 12+ Gnd and 2 datas (basically Gnd connections for up and down shift)
Hope this makes sense, keep me updated on how you get on if you managed to hardwire
Matt Current
Post #398268 29th Jul 2016 3:26pm
JPHC
Does make sense mate. Will have to rip the wheel apart this weekend and get the multimeter to work to get a good idea of how it's all setup for myself. Jordan
'56 SC 4.2 ‘16-‘18
Post #398271 29th Jul 2016 3:40pm
daveo
if i can remember i used the ground for the air bag for one and the live for the switches for the second V8 facelift Range Rover Autobiography 22" wheels.
Post #398326 29th Jul 2016 9:46pm
daveo
hi
if i remember Cam-Tech-Craig had a wiring diagram that he made,may be he can add it to the thread V8 facelift Range Rover Autobiography 22" wheels.
Post #398441 30th Jul 2016 5:50pm
JPHC
That would be great. Craig, you got such a thing mate? Thumbs Up Jordan
'56 SC 4.2 ‘16-‘18
Post #398630 1st Aug 2016 10:54am
Harris24742
2008 Range Rover Vogue 4.4 V8 Barolo Black
Retrofitting a 2012 steering wheel on 2008
Hi all. A newbie here. Can i retrofit a 2012 vogue's steering wheel on 2008 vogue? I know the paddle shifters can be installed after a little modification of thw wiring but the control switches is what bothers me. Would the nav and other controls function similarly? I mean is it a bolt on setup?
My apologoes for being a noob
Post #418461 18th Dec 2016 2:59pm
Pretty sure the "bus" systems are different so no you can't swap the airbag and switches, I think the bare wheel is the same though but you would have to check... Pete
-Click here for Thread-
Post #418485 18th Dec 2016 4:12pm
Harris24742
I actually want to put the 2012 instrumental cluster and the 2012 steering wheel. Paddle shifters aren't needed but would be nice if i could manage the wiring. What i don't know is that whether or not the control switches can be installed on 08
Post #418495 18th Dec 2016 5:26pm
mattstevenson2005
You can't fit a 2012 instrument cluster to a 08 L322. The MY59 L322 use a virtual instrument cluster and had a complete change in terms of wiring and CAN BUS. Pre MY59 vehicles use a 29bit CAN BUS whereas post MY59 vehicles use an 11bit CAN BUS network. The two are not interchangeable.
You can fit a 2012 steering wheel to a 2008 L322 although you cannot use the airbag or steering wheel controls, you will need to use your existing steering wheel controls and airbag. You can do the same paddle shift upgrade that i developed on your 2008 vehicle. You will just need to trace and locate the microswitch wiring for the shift up and shift down on the gearstick and wire the RF transmitter into these.
Matt Current
Post #418517 18th Dec 2016 7:21pm
Harris24742
2010? Or is 2010 and 2012 same steerings? Because there's no point of putting this if inwont be able to use the control switches
Post #418587 19th Dec 2016 7:52am
mattstevenson2005
Anything after mid 2009 uses the new system, only the older style steeering wheel controls will work with you vehicle.
Matt Current
Post #418598 19th Dec 2016 9:19am
Smiffyuk2017
Re: Retro fitting Paddle Shift to early L322
Unnecessary quote removed
Hello Matt
Sorry to drag up an old post but I need your help, basically I'm trying to use your expertise video and post but I can't seem to get it working, just to mention this isn't for a Range Rover, it's for a Mitsubishi fto and these can be done as I've tried and tested with bigger micro switches, the ones with the metal clips that move to the open or closed contact when pressed, is there any other way that I could make it into a switch with the Range Rover paddle shifters, even if it means adding wires! Please excuse my poor knowledge in electronics 😀 Hope you don't mind me asking about this, cheers
Stuart.
Post #431361 15th Mar 2017 10:34pm
Lukie
2002 Range Rover Vogue 4.4 V8 Zambezi Silver
in the FTO is the triptronic trigger by a negative pulse ?
Post #431366 15th Mar 2017 11:03pm
