![]() | Home > Maintenance & Mods (L322) > Retro fitting Paddle Shift to early L322 |
JPHC Member Since: 07 Sep 2015 Location: Kent Posts: 303 ![]() ![]() ![]() |
Thanks for the reply mate. Hmm might have to do that then...
mattstevenson2005 Member Since: 01 Jan 2011 Location: Manchester, UK Posts: 737 ![]() ![]() ![]() |
You would need an extra 2 tracks on the slip ring as the heating element has 12+ Gnd and data, and the paddle shift system needs 12+ Gnd and 2 datas (basically Gnd connections for up and down shift)
Does make sense mate. Will have to rip the wheel apart this weekend and get the multimeter to work to get a good idea of how it's all setup for myself. Jordan
if i can remember i used the ground for the air bag for one and the live for the switches for the second V8 facelift Range Rover Autobiography 22" wheels.
hi
That would be great. Craig, you got such a thing mate? |
Harris24742 Member Since: 18 Dec 2016 Location: London Posts: 3 ![]() ![]() |
Hi all. A newbie here. Can i retrofit a 2012 vogue's steering wheel on 2008 vogue? I know the paddle shifters can be installed after a little modification of thw wiring but the control switches is what bothers me. Would the nav and other controls function similarly? I mean is it a bolt on setup?
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8616 ![]() ![]() ![]() |
Pretty sure the "bus" systems are different so no you can't swap the airbag and switches, I think the bare wheel is the same though but you would have to check... Pete
I actually want to put the 2012 instrumental cluster and the 2012 steering wheel. Paddle shifters aren't needed but would be nice if i could manage the wiring. What i don't know is that whether or not the control switches can be installed on 08 |
You can't fit a 2012 instrument cluster to a 08 L322. The MY59 L322 use a virtual instrument cluster and had a complete change in terms of wiring and CAN BUS. Pre MY59 vehicles use a 29bit CAN BUS whereas post MY59 vehicles use an 11bit CAN BUS network. The two are not interchangeable.
2010? Or is 2010 and 2012 same steerings? Because there's no point of putting this if inwont be able to use the control switches |
Anything after mid 2009 uses the new system, only the older style steeering wheel controls will work with you vehicle.
Smiffyuk2017 Member Since: 15 Mar 2017 Location: Grimsby Posts: 2 ![]() ![]() |
Unnecessary quote removed
Lukie Member Since: 27 Sep 2016 Location: Liverpool Posts: 433 ![]() ![]() |
in the FTO is the triptronic trigger by a negative pulse ? |
